Those mounting holes measurements you took should be the same for either of the Axial transmissions though. The holes do seem pretty close to a Stealth's but it would probably work best to start with an undrlled RC10 chassis.
I keep those bearing in stock on my Imperial Bearing Cruiservintage AE wrote:I don't think it matters anyway. The outdrives require a imperial sized bearing, where the Axial case uses a metric bearing. I've got more photos to show that. It's quite close though.
Some SC10/B4.1 outdrives that use metric bearings. 10mmx16mmvintage AE wrote:I don't think it matters anyway. The outdrives require a imperial sized bearing, where the Axial case uses a metric bearing. I've got more photos to show that. It's quite close though.
Star Wars, Imperial Star Cruiser, your childhoodvintage AE wrote:Reggie, what are you talking about? I'm a bit slow and dense sometimes, ok often, what the hell is a Imperial Bearing Cruiser?![]()
Kyosho, HPI, and Tamiya all have 52t diffs with metric outdrives as well....so there's a few other options if the Associated parts don't work.jwscab wrote:The outdrive height can be less of an issue if you use the custom works, rc10gt, or any other type of hub that raises the axle.
I think CK33 has a nice solution with a plate and couple of small pieces of delrin for a bulkhead, or even modding a stock one.
looking at the axial trans, the output shafts look to be 5mm, so maybe a traxxas trx1 type diff can fit, though B4 parts seem like the easiest/least expensive path.
at that point, how far do you go before you end up with a B4 with a plate chassis
Reg, you know I'm only in my 20sCharlie don't surf wrote:Star Wars, Imperial Star Cruiser, your childhoodvintage AE wrote:Reggie, what are you talking about? I'm a bit slow and dense sometimes, ok often, what the hell is a Imperial Bearing Cruiser?![]()
vintage AE wrote:Reg, you know I'm only in my 20sCharlie don't surf wrote:Star Wars, Imperial Star Cruiser, your childhoodvintage AE wrote:Reggie, what are you talking about? I'm a bit slow and dense sometimes, ok often, what the hell is a Imperial Bearing Cruiser?![]()
Forgot about that, no offence but I was busy looking at your 18 yr old wife to notice much else
Yeah, I remember dinnervintage AE wrote:Forgot about that, no offence but I was busy looking at your 18 yr old wife to notice much else
she still gets ID'd you know
Users browsing this forum: azone,
Google [Bot],
mikea96,
TRX-1-3,
XLR8 and 2 guests
