Discussion about possible aluminum transmission and parts
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: Discussion about possible aluminum transmission and part
Post by klavy69 »
askbob wrote:Does anyone here know Atlas personally? He might be a good source to get CAD files for some of the parts in the drawings above.
I'm not sure he would be willing to give up his work to the 'competition' but you never know...
fredswain
Post by fredswain »
I work in 2D and 3D CAD. It's my job. I also own a 3 axis cnc. Time however is a problem.
Has thanked: 359 times
Been thanked: 470 times
That's for sure!!
flipwils11
Been thanked: 19 times
Post by flipwils11 »
Since a picture is worth a thousand words, I took this one of Alex's build and added some photochop ugly circles and labels. I can modify if people want other stuff (like the rear hubs which might be nice).
Ah, Alec was using a gpm b4 tranny-
Johnboy72
Post by Johnboy72 »
I've found the b4 transmission online but haven't seen a 6 gear or 2.25 yet.
PBR Allstar
Post by PBR Allstar »
saw a mention of the case I sold, since it was a classified I took down the pics, but I still have them so here they are if anyone wants a gander.
300D50
Post by 300D50 »
Yeah, saw those, wasn't sure if that was the exact style everyone had in mind.
Are the bearing bores press-fit, or slip-fit?
I found this link to a bearing kit on TH in one of the other threads, so I now have a bit more of a sense of the scale of this, as well as bearing diameters.
Pulling the first photo into a sketch in Inventor, then scaling it so that the bearing race dimensions fit gives me a center to center of .5 for the top gears, and .75 for the bottom. That at least seems to be the most logical, but I'm likely wrong.
Going by that, the axle shaft/diff gear(s?) seems to be 1.0 inch pitch diameter, with 0.5 inch pitch diameter for the other remaining gears.
Anyone care to confirm?
Walt
Some people never have anything except ideas. Go do it.
Johnboy72
Post by Johnboy72 »
I really need to get the stuff down to ya. lol. Then you can see first hand brother.
wyldbill
Post by wyldbill »
i would definatly be up for 2 or 3 cases in black delrin and bulkheads too.
I can say that 99% of everyone will want slip fit, the damn 3/16 X 5/8 bearings are hard enough to get out of the stock nylon slip fit cases :lol:
300D50
Post by 300D50 »
Ok, thought it would be slip, but wasn't sure.
I'm pulling down the cad models from mcmaster right now, I figure I might as well play with this a bit more and get a rough model rigged up while Johnboy and I work out the timing.
Charlie, did you mean 1/4X5/8? I can't seem to find a standard bearing in 3/16X5/8. Is it a special item?
Walt
bearings are 3/16" x 5/16" for the top and idler, unflanged.
outdrive bearings are 3/8" x 5/8" unflanged.
SnoopMaxx
Post by SnoopMaxx »
Walt they are 3/16 x 3/8 plain (for transmission case topshaft, idler and front wheels)
and 3/8 x 5/8 plain (for transmission case Diff)
They are in the link you have in your post
Morten
Morten Max
300D50
Post by 300D50 »
Ok, good, so I at least got that part correct.
Anyone care to throw up some basic measurements of the height, length, and width for this sucker?
I can't really pull that from the image because of the tilt distortion.
I figure the more info I can get before I have anything in-hand, the better prepared I'll be to get things going.
Walt
Users browsing this forum: No User AvatarAhrefs [Bot] and 11 guests
