'da blue guy
RC Chick
Post by RC Chick »
That is a nice car. I ve been wanting to do that to mine. Im buying it peice by stinking peice now that I finally have my sons T2 running and I just picked up anohter T2 off ebay that was ready to run. Id post pictures of my trucks that really aren't much to look at but I can't find my usb cord to my camera. I think the guy that lives in the dryer that takes socks got out and stole it. LOL.
Volumiza
Post by Volumiza »
scr8p wrote: the rear rpm bulkheads pop up on ebay every now and then. but be prepaired to shell out some dough for one. :wink:
i live in the UK so ebay is pretty much my only avenue, i'm getting quickly used to paying high :( but when you want something, you have to have it :wink: .
"I want to die peacefully in my sleep like my grandfather, not screaming in terror like his passengers!" The late great Bob Monkhouse 1928 - 2003.
Volumiza
Post by Volumiza »
scr8p, how much modification to the pan did it take to get those wide rear RPM arms to fit. does the pan have to be cut (i can see yours looks like it has) and if so, which holes are you using to fix the suspension mounts in place?
a nice photo of the underside would be nice :wink:
when you get the worlds rear suspension kit, it comes with a template to do the mods to the chassis. after the chassis is cut out, you'll only need to drill 2 holes for the front of the arm mounts. the back of them attach through the existing stock trans mounting holes.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
scr8p wrote:well, the front bulkhead on this car is a standard rc10t. the narrow rpm bulkhead will not let you attach the nose brace tubes to it. rpm front bulkheads are almost non existant, from what i've seen. the rear rpm bulkheads pop up on ebay every now and then. but be prepaired to shell out some dough for one. :wink:
I am working on getting some, will start a new thread if/when it comes through. Some meaning more than I need.....
Volumiza
Post by Volumiza »
i see, cheers.
Volumiza
Post by Volumiza »
i like the sound of that JK, a rear bulkhead is stalling one of my projects. if there's one going spare then i'll be more than happy to lighten your load :wink:
Synergy
Has thanked: 127 times
Been thanked: 72 times
Re: 'da blue guy
Post by Synergy »
Please can someone advise me if these blue shocks are available in .71 size or just 1.32 and 1.02 :?:
Thanks.
Here's my TC Showroom
Tadracket
Re: 'da blue guy
Post by Tadracket »
FERRETTI wrote:Please can someone advise me if these blue shocks are available in .71 size or just 1.32 and 1.02 :?:
Thanks.
A quick search of Tower says "No way, Jose'".
But tower is not the end all of RC info, although they are pretty accurate.
He's an idiot. Comes from upbringing. His parents are probably idiots too.
Re: 'da blue guy
i've never seen blue ano'd .71's. however, the b4 rtr kit has blue shock bodies, but the fronts are .89's. i know they're still as liitle long, but not as long as a 1.02. :wink:
i have never seen the bodies sold seperately, though. :?
Synergy
Re: 'da blue guy
Post by Synergy »
Thank you chaps, it's as I thought, unfortunately .89 would be too long, ho hum.
Tadracket
Re: 'da blue guy
Post by Tadracket »
You could strip a set and anodize them yourself. I would do it for you but I still don't everything set up in my garage yet.
Synergy
Re: 'da blue guy
Post by Synergy »
Thanks for the offer Tad :) , I'm not bothered enough to go to too much trouble, I'll just pick some of the teflon ones up from tower when they get them back in. I just wanted a set of new none leaking shocks for a runner and thought these blue ones looked coolio 8)
Chewbacca
Has thanked: 51 times
Been thanked: 108 times
Re: Gear Cover...
Post by Chewbacca »
You might want to check THIS out
black, yellow or BLUE!!
scr8p wrote:i don't think i'll be able to put a gear cover on it. with the way i mounted the b3 motor plate, the gear cover would probably hit the outdrive. although, i could notch it out. i don't think they make them in white for the b3 though. :?
it'll most likely just get a white spur, and a blue pinion if i can find one.
the rear tires are TQ-21's.
*** POWDER - KING ***
rookie rc10
Re: 'da blue guy
Post by rookie rc10 »
nice frame luv the blue
Users browsing this forum: No User AvatarGoogle [Bot] and 4 guests
