the modernized ultramolded truck project **now 99.9% done!**
Re: the modernized rpm ultramolded truck project
The use of those hubs is somethin ive been thinking of doing to my racer. I like
Very nice truck and really digging all the info in it.
- Charlie don't surf
- Has thanked: 358 times
- Been thanked: 470 times
Re: the modernized rpm ultramolded truck.. cva problem sol
Hand lathing, hell he was at plasma cutting, die grinding and then sleeving and braising before we figured the T4 CVA thing outGroup B wrote:so you want to run GT2 quick-change, huh?lowrydesign wrote:lowrydesign wrote:
Sun Sep 26, 2010
ran into a bit of a problem with the rear drive system....
the goal is to use gt2 cva's with the posi lock quick change
here are the issues i ran into.
i wanted to use the rpm hubs originally but,
- rpm hubs put the drive pin 2mm too far into the outdrive, and they bind at full compression..
so i tried a set of t4 hubs but,
-t4 hubs put the drive pin right on the edge of the outdrive.
this was solved by using t4 cva bones.. go figure.. they are 3mm longer... THANK YOU Reggie aka "charlie dont surf" for brainstorming with me
There's something I'm not understanding...here's the guy (lowry) who invented the "hand lathe" technique, and he could have easily used said technique to "thin-out" the end of the cva bones for clearance...
- lowrydesign
- Has thanked: 11 times
- Been thanked: 22 times
*update*
i finally got it all done..... well except for the parts ill change out later, ie; batt cover and maybe the white will get exchanged with black ones.. but other than that i took it to the local track today and put a few batteries though it. the truck ran well other than the track was quite loose and the tiers i have weren't really set up for the surface conditions that were present, plus it has a 6.5 in it, so power comes on fast to say the least. but i am very pleased with its first outing.
here are some pics of it after i got back from the track
- vintage AE
- Has thanked: 29 times
- Been thanked: 36 times
Re: the modernized ultramolded truck project **now 99.9% don
what's the last 0.1%, cleaning the tires
job well done!
- Toasted Coastie
truck is so beautiful dude. I'm ready to build one as well, but have to find one....
- lowrydesign
haha black shocks and a black battery covervintage AE wrote:what's the last 0.1%, cleaning the tiresjob well done!
lowrydesign,vintage AE wrote:some RC10 projects with RPM team car arms are using B4/B44 alloy hubs and milling out the inside so that the longer B4 cva bone will fit the out drive properly.
What slipper plate are you using for your Rig, would it be possible to send the link to me,
got the same truck for my Son as Christmas Gift, yours is an inspiration,. love the idea of the Red/Black theme...
but still have to wait for the Tranny
I will be re-reading this thread coz will also do the Quick release tires... ......
thanks.
Jun.
― Confucius
― Confucius
- Has thanked: 36 times
- Been thanked: 1318 times
Thanks scr8p,
tried searching in Amain and Tower... you dont happen to have the link on where to buy it would you?
thanks,
thanks,
― Confucius
― Confucius
i hunted around quick, but couldn't find any.slow_jun wrote:you dont happen to have the link on where to buy it would you?
they're probably junk. the only place i can say i've seen them is at the bottom of the 50% off box at the local hobby shop.
ahhaha. but the problem here in SG, most of the LHS are new so no old stocks hanging around the rack, anyway, thanks Merry Christmas to all!!!!!
― Confucius
― Confucius
i'm pretty sure i have a new pair, and i doubt i'll ever use them. i'm in the process of straightening up my basement / rc area. if/when i come across them, i'll let you know.
Thanks Scra8p, will just wait for it... happy Holidays guys!!!!!!
― Confucius
― Confucius
- 733 Views
Last post by Momo5
- 36 Replies
- 3018 Views
Last post by THEYTOOKMYTHUMB
- 34 Replies
- 6604 Views
Last post by bully
- 21 Replies
- 5330 Views
Last post by Twistedaxle
- 1085 Views
Last post by Group B
- 1453 Views
Last post by Trackingz
- 720 Views
Last post by joey_zrl
- 44 Replies
- 10186 Views
Last post by HiTec
