Nothing is completely together yet because I need shims. The spacers for the rear make it too tight to put the hexes on the axle, so I won't be using them. The universal dogbone end, once everything is assmbled and shims are in place, ends up half way into the cup, ensuring no binding. When everything is together, I'll take pics.....Mr. ED wrote:How wide does the rear end up at with the stock cast carriers and UM-510?
(there are 2 blue spacers included with UM-510, they should probably go on the outside; otherwise the axle reches to deep into the outdrivecups of the diff and will bind when the suspension is compressed.)
Yokomo YZ-10 870c Square hub to standard Hex hub conversion
- Toasted Coastie
Re: Yokomo YZ-10 870c Square hub to standard Hex hub convers
- Toasted Coastie
It is done. The car is done. The wheels/universals with shime works fantastic. I test drove the car tonight and it just kills with the new rubber.
For the fronts, I used 3 1mm shims (washers). For the rears, a 4mm (?) shim and a 1mm shim. Awesome. The only problem I have now? The pinion gear is too big. After the test run, I noticed some lexar melt around the motor.
Thank you so much folks, this is awesome.
- Toasted Coastie
Right from my receipt:
1 LA218 Drive Washer(ZX-5) USD$ 4.99
1 LA257 Universal Swing Shaft (73/ZX-5USD$ 47.99
1 UM510 Universal Swing Shaft (62.5/RBUSD$ 49.99
2 W5026W NARROW WHEEL(56 SIZE) USD$ 9.98
2 W5028W WIDE WHEEL(56 SIZE/WHITE) USD$ 16.00
The shims had no part number, I went right to New Era, and they fitted stuff for me, and gave them to me loose. I have to stop by there this weekend with the car so they can see the end result...
Dirt tires are: http://prolineracing.com/1-10-buggy-tires-caliber
but I still need to get street tires.
I bought two sets of wheels so I could put street tires on one set, and dirt tires on the other. Pictures later tonight....
are you running the front suspension in the 'wide' configuration? That is, do you have the c hubs mounted in the outermost mounting point on the suspension arms?
thanks for the parts list. those prolines look sweet.
- Toasted Coastie
The front carriers are on the outer most. If I put them on the inner mount, I think that the universal would probably bind.
All the shims are on the inside of the carriers, rather than the outside behind the hex. I really don't know how else to explain that.
I bought different shocks for it to give it a more even stance. They are these: http://www.rcxmini.com/product_info.php?products_id=2351
They were shorter than the ones I had on there, and the blue/aluminum looks nice on there.
- Toasted Coastie
I think I originally misunderstood your question. Tonight when the kids go to bed I'll take some pictures and post them.jwscab wrote:are you running the front suspension in the 'wide' configuration? That is, do you have the c hubs mounted in the outermost mounting point on the suspension arms?
no, you answered the question fine. So the lazer cvds that are 73mm are used in the 'wide' configuration. The narrower setup I think is around 5mm shorter,so you'd need something like a 68mm shaft, which is the other option from kyosho, I think. and all the shims are on the cvd side of the axle, no problem there.
please post a pic though, it will be very helpful and informative for others as well.
great work!
great work!
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
I tried with my 68mm shafts from academy, but they went into the doutdrives of the diff just a little too much: they'd start pushing on the diff before the suspension was fully compressed. (You could maybe avooid that by re-arranging the top links position so the tire does not lean in when compressed but then you loose traction up front when cornering).jwscab wrote:no, you answered the question fine. So the lazer cvds that are 73mm are used in the 'wide' configuration. The narrower setup I think is around 5mm shorter,so you'd need something like a 68mm shaft, which is the other option from kyosho, I think. ...
great work!
I'm thinking of trying with tamiya 78mm cvd's upfront; using the wider rear arms and later lazer SP front wheels, but the axle part on them is really really short.
- Toasted Coastie
Before you look at these pictures, a couple of things I should warn you about:
1. Apparently, I suck at glueing tires
2. I ran this car today, and never blew the dust off afterwards. Sorry
3. I did not do a restore like some of you folks on here would have, I want this to be a runner.
Now, for your viewing pleasure:
Front:
Rear:
I really haven't figured out the whole toe in/out thing, and everytime I adjust I go too far one way or the other:
And I just niticed in that last picture, I lost a king pin again.
Front:
Rear:
- Toasted Coastie
So I changed the tires to Proline Dirt Hawg, and did a beeter job glueing them. Also, this car is a madhouse driving it now. Thank you everyone for all the help!
- Has thanked: 170 times
- Been thanked: 23 times
Re: Yokomo YZ-10 870c Square hub to standard Hex hub conversion
So. What was the final recipe for hex conversion on an 870c / AE YZ10 with the wide front end?
- 1215 Views
Last post by MONSTER
- 1245 Views
Last post by Group B
- 1690 Views
Last post by ralphee
- 2291 Views
- 776 Views
Last post by Bottom Feeder
- 1011 Views
Last post by minimini
- 764 Views
Last post by cautrell05
- 563 Views
Last post by Dadio
