- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Thanks
Almost certain it's 27 turn stock and it does have a staked endbell.
Magnets don't feel real strong either.
Leaning towards Twister now as I just found another motor, very similar, with Twister label.
Though the Twister labeled motor seems to have better magnets.
Chuck
Chuck
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
nope not movable: clear from the missing screws in the picture and the capacitors soldered on the can
- Mr. ED
for which car is this? Metric with bigger bearing on the inside versus outside. But most remarkable lower and upper pivot points don't line up.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
not exactly sure but they look similar to the front steering knuckles for my sc10 4x4 or the shaft driven sc10 4x4. Got a pair for it and never installed them but haven't seen them in a few years so don't quote me on it. Be a place to start the look though maybe...
- Mr. ED
I think they are a bit older than that. I assumed they'd go on an onroad car: with a balstud up and under and swingarms top and bottom: no C carrier
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
I can’t emember the brand of this chassis. Also, any sugestions on front shock tower tor the wide front end?
Thanks limestang
Thanks limestang
- Has thanked: 170 times
- Been thanked: 23 times
BME and wide Hot Trick Front end. Hot Trick and Composite Craft both made the wider front shock towers!
- Has thanked: 36 times
- Been thanked: 1318 times
- limestang
Correct, that offset is tricky- I’m having difficulty fitting a front sock tower. I found a wide one made by Trinity and the mount holes don’t line up. The front shocks also need to be different lengths. I’m going to need to do some research.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
The BME kick-up is essentially half a stock width kick-up and half a Hot Trick wide kick-up. Used a BME specific tower or one of these Hot Trick oval towers:
Or you can do what I did and make your own (the aluminum one).
- Phin
Noticed this Tamiya factory built Road Wizard based speed run car in the June '90 issue of RCCA and was hoping to ID the body. Is it actually "off the shelf" like the article mentions?
Also, if you've seen any other pics (or videos) of this car on the WWW please give links.
- Basher67
- Has thanked: 44 times
- Been thanked: 160 times
Trying to verify who made these plates. Not sure the correct technical name---motor plate, pod side plate, axle carrier plate. I picked up a few sets of these with some vintage drag cars and parts. The components that were used with them were mostly AE 12L. The guy I bought them from said he thought they were Hogue but couldn't remember for sure. Not sure if they are drag specific or possibly a carry over from pan cars. Anyone recognize these?
- Has thanked: 1129 times
- Been thanked: 3919 times
The Houge Illusion used them, and they probably were harvested off another rig as well.
- Basher67
Thanks Jeff! That was even more helpful, because the complete car that I have has that entire rear pod/axle on it. Even the same wing mounts.
- 59 Replies
- 16055 Views
Last post by Diamond Dave
- 106 Replies
- 27068 Views
Last post by mikesofunny
- 431 Replies
- 54278 Views
Last post by Eccentric
- 67 Replies
- 16808 Views
Last post by bearrickster
- 321 Replies
- 41744 Views
Last post by tazz888
- 448 Replies
- 49836 Views
Last post by MelvinsArmy
- 351 Replies
- 47367 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
