So, what did you do RC today?
- morrisey0
- Has thanked: 87 times
- Been thanked: 1852 times
Before I went to bed last night, I threw together a really quick design for my Hilux bed rails (the originals are missing), and printed them as a first draft. Surprisingly, they came out better than expected and I am calling them final. Wasn't planning on printing as much as I am on this vehicle, but even when I can find some of these parts, I am not paying the prices that people want.
The next guy can make it perfect it he wants to.
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Was out driving the junk box mutt, power-slidding through my neighbors long (300'+) gravel drive. All of a sudden, the truck came to a complete stop.
Somehow, this big ass rock (23X18X11) managed to get jammed in between the wheel and control arm.
I had to remove the wheel to get it out. These are deep offset wheels (Traxxas rear), so it did something special to get in there.
At the same time, I managed to snap off a front camber link ball stud. But that didn't really surprise me, as this truck is mostly built with the worst looking hardware that I had.
- TravelinTravis
- Has thanked: 987 times
- Been thanked: 372 times
Soldered up a 10W 30ohm resistor, and started cycling some 1400mah SCR's.
- juicedcoupe
That reminds me. I've got a Dean's Blackbox and some Trinity discharge resistors that I need to put together.TravelinTravis wrote: ↑Wed Aug 09, 2023 7:06 am Soldered up a 10W 30ohm resistor, and started cycling some 1400mah SCR's.
- NWarty
- Has thanked: 23 times
- Been thanked: 21 times
Painted the Schkee body on my Bolink Eliminator. Some paint boo boos here and there, but nothing that can’t be covered up by decals (plus, I’m going to run it). I had Nathaneal at MCI print me a custom sheet of fictional liveries that should be here today.
It’s now got a Hobbywing 1060, Reedy motor, and FlySky Rx.
This is the inspiration.
- Attachments
- f84971473ba0aa8361690cc6c301aff7.jpg (28.29 KiB) Viewed 1310 times
A bit different
- juicedcoupe
Done, and done.juicedcoupe wrote: ↑Wed Aug 09, 2023 8:24 amThat reminds me. I've got a Dean's Blackbox and some Trinity discharge resistors that I need to put together.TravelinTravis wrote: ↑Wed Aug 09, 2023 7:06 am Soldered up a 10W 30ohm resistor, and started cycling some 1400mah SCR's.
I had forgotten how much I hated the larger Dean's Ultra Wire. I said screw it and crimped some automotive terminals on it.
- Has thanked: 1243 times
- Been thanked: 639 times
Decided to update my goldpan DS build with one of the new 6001 chassis that I picked up.
- Has thanked: 1153 times
- Been thanked: 624 times
I’ve been messing around with the idea of making a Comical Jrx2 on paper before I cut up a chassis.
-Brad
- Has thanked: 1129 times
- Been thanked: 3917 times
Ugh oh
This was my project yesterday
Going out for powdercoat Monday
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
Making standoffs for a few projects. I needed 16 of them and only broke one 4-40 tap.
- juicedcoupe
Pre-drill the hole with a 3/32 bit instead of the included one. It will still cut full threads but taps much easier.Frankentruck wrote: ↑Sun Aug 13, 2023 9:49 pm Making standoffs for a few projects. I needed 16 of them and only broke one 4-40 tap.
Holding the tube will shock pliers helps as well.
- Frankentruck
The K&S tube is already the right hole size for 4-40 tapping, I just need to not be lazy and get too aggressive with the thread cutting.
My 2 chucks setup overall works reasonably well, one for holding the tube and one fof holding the tap.
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
My 2 cents
Probably too late now...
Get rid of those awful Irwin taps. I hate those things
Amazon Drill America - DWT57048 4-40 High Speed Steel 2 Flute Spiral Point Tap, DWT Series
No need to overdrill the aluminum.
I am sure there are even better taps but I like these taps waaaay better. Only a little over $5.
And I haven't broken on of these 2 flute taps yet, broken several Irwins.
Stronger, sharper and tap deeper.
Chuck
My 2 cents
Chuck
- Frankentruck
Never too late, thanks for the tip. I hadn't found a 4-40 tap I liked yet and always have more need for threading.
- 5570 Views
Last post by Dr. Robotnik
- 20 Replies
- 10379 Views
Last post by cas22
- 6463 Views
Last post by Synergy
- 6693 Views
Last post by ireg
- 5722 Views
Last post by clm
- 2721 Views
Last post by mrlexan
- 2426 Views
Last post by DHood
- 2572 Views
Last post by Winger
