It's a 306 as well. I'm slowly collecting parts for a stroker Windsor, very slowly.
Luckily, it was at idle when the lifter came apart. I was able to save the rotating assembly.
Of course junkyard 351 blocks can be had for quite cheap. 347 and 408 stroker kits are in the same ballpark price wise (machining cost is the same), but the 408 is in a different league than a 347. And there's the added bonus of having a superior factory block. Not sure what your plans are, just thought it can't hurt to mention.juicedcoupe wrote: ↑Wed Apr 07, 2021 10:23 amIt's a 306 as well. I'm slowly collecting parts for a stroker Windsor, very slowly.
Most likely, a 408. And I'm well aware of the differences in block strength, which would be my primary reason for going to a Windsor.R6cowboy wrote: ↑Wed Apr 07, 2021 10:43 am Of course junkyard 351 blocks can be had for quite cheap. 347 and 408 stroker kits are in the same ballpark price wise (machining cost is the same), but the 408 is in a different league than a 347. And there's the added bonus of having a superior factory block. Not sure what your plans are, just thought it can't hurt to mention.
Not happening. Other than looks, there is no reason to build a Clevor anymore.
Bust out the bank account
So agree with this. To me a 450whp, 11.3 et @ 128mph n/a car (avatar) is more enjoyable than, for example, my good friend's 760whp turbo Supra.juicedcoupe wrote: ↑Wed Apr 07, 2021 11:37 am At any rate, faster cars aren't as much fun to me. Quick, budget cars are more enjoyable. I'm taking about the kind that you don't really care if you break it.
And thats why I always cut stringers and use center supports. They aren't as attractive but are sooooooo much stronger.
juicedcoupe wrote: ↑Wed Apr 07, 2021 12:25 pmAnd thats why I always cut stringers and use center supports. They aren't as attractive but are sooooooo much stronger.
Cutting stringers for stairs that long would be time consuming though.
"Had" is probably a very fitting word...... as it seems to come and go in short burstsIncredible_Serious wrote: ↑Wed Apr 07, 2021 3:10 amSo you're saying you had money AND motivation???? Lucky sod!
Make sure you post that photo tomorrow.....juicedcoupe wrote: ↑Fri Apr 09, 2021 4:00 am Just got awakened by a hail storm, at 3am. I can't wait to see what my truck looks like.![]()
Tbot [Bot] and 4 guests
