- Phin
- Has thanked: 87 times
- Been thanked: 249 times
It's a delta shock with an IRS extended spring retainer. Used on pan cars in the mid/late 90's like the Wood Racing X-13. You can see how they'd work on my Wood Racing car: http://www.rc10talk.com/download/file.php?id=104529&mode=view
The IRS retainer is a beefier version of what I did...which was what I've typically seen done, screw a long tube on the end of a regular delta spring retainer. Also I believe the spring inside is to create rebound when the rear axle droops.
- Phin
Dunno specifics.
Might be there's a benefit moving the shock mounting point closer to where the rear pod actually pivots...especially on link cars or the Wood Racing cars that had pivot balls inside the t-bar where it connected to the rear pod. Or it could just be that the move to side shocks/dampner tubes created a void where the dampner discs used to be and the shocks had to get longer to reach the pod.
Whatever the specific reason longer shocks seem to have stuck around to modern pan cars.
- XLR8
- Has thanked: 1696 times
- Been thanked: 1199 times
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
- Has thanked: 170 times
- Been thanked: 23 times
OK. I have several of these and really have no idea WTH they are! Anybody???
- Phin
Never seen them before.
The keyway in the center makes me think they're supposed to spin on an axle or shaft so I want to guess at some kind of wheelhub or gear adapter.
- Been thanked: 507 times
yeah, once I was able to look at the pics up close, they look pretty concentric, so some kind of wheel hub/axle adapter. maybe some kind of pan car?
I figured it out! I thought the part was MIP related and I was correct. Super Diff. parts for the Big Bear.
- Has thanked: 1136 times
- Been thanked: 3945 times
Oh wow! I never would have guessed- never seen the big bear diff kit
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
AIP47, P.I.
didn't even know Eustace did anything for Marui cars
Can someone take a guess at what is inside this Trinity bottle? All I know is, it's vintage, it's very fluid but not as liquid as, say, gun oil (not sure how it's called in English, sorry), and it's pink-ish... I use it on stuff sometimes when the risk level is low
Thanks!
Paul
Thanks!
Paul
nice job on the marui investigation. That's kind of what I was thinking, some kind of diff parts, but for a pan car with the 'D" and woodruff key slot. The diff makes perfect sense.
Lonestar, what does it smell like? I would guess it's just a 'custom' machine oil. I have a trinity oiler, but I don't know if I bought it full or if I put machine oil in it.
- 59 Replies
- 16480 Views
Last post by Diamond Dave
- 106 Replies
- 27646 Views
Last post by mikesofunny
- 431 Replies
- 55922 Views
Last post by Eccentric
- 67 Replies
- 17326 Views
Last post by bearrickster
- 321 Replies
- 42796 Views
Last post by tazz888
- 448 Replies
- 50976 Views
Last post by MelvinsArmy
- 351 Replies
- 48151 Views
Last post by Frankentruck
- 4295 Views
Last post by mrlexan
