So, what did you do RC today?
vonBraun
Has thanked: 41 times
Been thanked: 69 times
Post by vonBraun »
Since it’s been raining for the last few days I decided to cheer my self up with a quick rebuild of my recently acquired Worlds Car today.
The diff gear ist the only part I had to replace so far.
No peroxide treatment this time because I ran out of H2O2. I might do it in the future…
Now I just need a wing, wire, buttons and a set of Pro-Line Pro86s to complete it.
And do a lot of detail fiddling of course :lol:
I like trucks and I cannot lie :lol:
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
GoMachV wrote: Wed Jul 26, 2023 12:14 am 7 1/2" with the old school front end and trailing arms. I took out 3" total so with conventional arms it might vary just a tad
I’m kinda thinking about doing this now to an extra JRX2 I have.. it can be shortened 1.75” and still retain the 5-link. A rear H arm setup could go 3”
-Brad
Has thanked: 2604 times
Been thanked: 2977 times
BattleTrak wrote: Wed Jul 26, 2023 2:33 pm
1.75" shorter doesn't seem comically shortened, but the 5 link setup would be cool to keep. The front connection for the 5 link could probably go a little way further in on a narrowed chassis before there was binding at the pivot balls. A little measuring and geometry, or some experimentation with the lower link removed might give an idea what location changes will still work. Or a 3D printed forward connection block that keeps the links out wide might be another option.
RogueIV
Has thanked: 2133 times
Been thanked: 1099 times
Post by RogueIV »
I have an absolutely trashed chassis that I'm now definitely going to do this with. H-arms though and Pro towers
RogueIV
Post by RogueIV »
Well just modeled this:
now to scale it down for the Mini JRXT.
morrisey0
Has thanked: 87 times
Been thanked: 1852 times
Post by morrisey0 »
I spent a little more time on the Bandustlerpede. Went shopping for all the mechanicals I need, and remembered all the little stuff, and then completely forgot rear susp arms. :D Oh well. Printed out a support for the rear shock tower so it fastens at four points as intended. Also went through and refreshed the trans and installed bearings. Body and wheels should be here this weekend.
TravelinTravis
Has thanked: 987 times
Been thanked: 371 times
Post by TravelinTravis »
Finally got the solder station, so started turning some stick pack SCR's I got a while back into saddle packs.
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
Sat around watching more ai generated art...
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
working on a project a friend requested
morrisey0
Post by morrisey0 »
Made my Hilux trans do stuff. Sounds a bit rough because the mic is close, the spur gear is printed and not exact, and it has an 11t pinion instead of 10t (non-adjustable) because well, that is all I have and the correct gear is hard to find. In the VERY limited time this is going to be run while in my possession, it is just fine. :D The next guy can work all that out if they feel the need.
clm
Post by clm »
RogueIV wrote: Wed Jul 26, 2023 6:31 pm
What about a stubby Mini LXT? ;D
https://www.tinkercad.com/things/jj8HFpavuEe?sharecode=riRGZKKg5kMU4J9xbODHO6u88-9GensH8UF3nKkr_j4
You can grab stls from tinkercad or see the hackjob I did to them if you want :)
I did up a short 5 link suitable chassis for those type of weird people too lol
NWarty
Has thanked: 23 times
Been thanked: 21 times
Post by NWarty »
Cut the SabulaTech Schkee body for my Eliminator 10. Made from the original Bolink mold. Also mounted up some fresh new foam wheels/tires.
A bit different
Been thanked: 3917 times
Started filling one of my new(to me) cases. The other case will be batteries and motors
Retro rc
Has thanked: 665 times
Been thanked: 473 times
Post by Retro rc »
GoMachV wrote: Fri Jul 28, 2023 5:45 pm Started filling one of my new(to me) cases. The other case will be batteries and motors
Holy rare items in a glass case Batman……… if that’s just the beginning I can’t wait to see the rest😱
dldiaz
Been thanked: 58 times
Post by dldiaz »
Moved an old Losi project out of the way so I can start getting VONats cars ready:
-dldiaz
