DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
Phin wrote:1) Holiday Buggy front wheels & tires.
2) Adapters for a dually rear set up on the back of SRBs. Often seen with a set of ski's replacing the front wheels. ;)
http://www.rc10talk.com/viewtopic.php?f=35&t=21245
3) Don't recognize those. Maybe Brat fronts?
Little Willy won´t go - I think they´re wild willy´s
Gone fishing
crusaderlyf
Post by crusaderlyf »
V12 wrote:Bought some stuff a couple of years ago and this is what´s left now. I think all Tamiya stuff but not sure which cars go for. Someone have an idea?
good looking adapter, want to make a car use it
orangemazda
Has thanked: 14 times
Been thanked: 60 times
Post by orangemazda »
Thought this was an RC10GT rear shock tower but not sure, couldn't find a match on ebay. Any ideas?
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Looks a lot like the Factory Works GT rear tower I have but it's definitely different. :|
Been thanked: 1319 times
Probably composite craft. I think theirs had the "x" section.
R Cane
Has thanked: 159 times
Been thanked: 64 times
Post by R Cane »
I just spent hours tonight sorting and ID'ing several boxes of misc parts...I have a few here that I can't ID, hoping for some help from the gurus (that's you guys). Some are pretty dirty, I know.
standard gold pan color, but I haven't seen this shape before...newer part? I admit, my knowledge of the more modern cars is lacking...
transmission case...
Andy's hoobajoob...
tower...
pan car bumpers I assume...
Been thanked: 3919 times
Traxxas bullet and radicator motor plate, modified
Kyosho optima rear trans housing
Andys oval/truck body mount for rc10 6 gear
Kyosho Ultima 2/outlaw Ultima rear tower and bulkhead
R Cane
Post by R Cane »
:D
Phin
Post by Phin »
Kyosho Assault bumpers.
R Cane
Post by R Cane »
Hmm...I was off on that last one...
:lol:
Thanks guys
I kept thinking..."why the non symmetrical holes?!" But he nailed it. Those are for the spring that holds the glow plug battery.
yellowdatsun
Post by yellowdatsun »
What I have here, is what appears to be, a steel bushing. The size is 10mm tall, with a 5mm hole, and 4mm thick. Does anyone have a clue what this came off of? It was in my RC screw bin, so I am assuming it's RC related.
I need to find either a duplicate, or maybe a couple bronze bushings. I need to end up with two in the 10x5x4 size.
**ORRrrr** I need another way for a 15mm hole to accept a 5mm axle. I've found they don't make bearings like that with a 4mm depth. I have a 15x10x4 bearing, that I was hoping to slide a 10x5x4 bushing into, since they don't sell 15x5x3 bearings.
Has thanked: 1737 times
Been thanked: 1145 times
yellowdatsun wrote:What I have here, is what appears to be, a steel bushing. The size is 10mm tall, with a 5mm hole, and 4mm thick. Does anyone have a clue what this came off of? It was in my RC screw bin, so I am assuming it's RC related.
Tamiya M03M utilised 1050 bearings on the front and rear hubs, for something relatively recent. Going back a little further, the Kyosho Raider utilised 1050 bronze bushings in the gearbox and other places... those are just two examples.
I think the 1050 was Kyosho's standard 'normal' bearing, much like Tamiya's utilisation of 1150 bearings wherever possible. Any old Kyosho kit box / spares box should have heaps. If you can't find any local, let me know and I'll dig through a box or two.
yellowdatsun
Thanks a lot! It looks to be a Kyosho Optima bushing, and even has the same bevel on the inner circle. Makes sense, since I used to have an Optima 20 years ago.
Fracek
Post by Fracek »
Hi, maybe some one knew this two models with white and black bumper.
Thx for your help.
Return to “Identifications”
