Discussion about possible aluminum transmission and parts
SnoopMaxx
Re: Discussion about possible aluminum transmission and part
Post by SnoopMaxx »
Awesome :lol:
Morten Max
300D50
Post by 300D50 »
So this happend Christmas Eve.
Start of the rigid fixture blank for the run.
3.5x2x12 aluminum.
Faced off one side in the VMC, then ripped the strap slots down the side by hand on the Bridgeport.
Strapped it down, indicated along a cut surface, then faced again.
Last photo is from 03:00ish Christmas day, and has the beginning of the table lock profile.
Grabbing three slots on the table, just because I can. :mrgreen:
The fixture blank should be finished sometime today, if time permits.
Walt
Some people never have anything except ideas. Go do it.
SnoopMaxx
Post by SnoopMaxx »
Two thumbs up
And Merry Yule Walt
Morten Max
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
8)
300D50
Post by 300D50 »
Freezing rain Monday, snow plows overturning in ditches, fire trucks sliding into trees...
Decided to stay home. :lol:
Walt
300D50
Post by 300D50 »
This is what's currently in my cart over at tower.
Qty SKU Description
1 LX2864 Associated Stealth Idler Shaft & Gear
1 LX2865 Associated Stealth Drive Gear Shaft Assembly
1 LXFXFN Associated Stealth Transmission Case
1 LXPA07 Associated Differential Rebuild Kit TC3
1 LXEDZB Associated Differential Outdrive Hub Right RC10
1 LXEDZC Associated Differential Outdrive Hub Left RC10
1 LX2873 Associated Stealth Differential Gear
1 LX2874 Associated Stealth Carbide Differential Ball 3/32" (12)
1 LXD082 Duratrax Bearing 5/32x5/16" (2)
1 LXD095 Duratrax Bearing 3/8x5/8" (2)
2 LXD088 Duratrax Bearing 3/16x3/8" (2)
Everything look good?
Walt
You need (4) 3/16 x 3/8 bearings
300D50
Post by 300D50 »
I think I have 4 in there, Tower has them as 2 packs.
Ended up being cheaper than VXB/McMaster to just get the bearings from Tower.
Everything else look ok?
EDIT:
Ordered the whole shebang, should be in next week, except the backordered pinion shaft.
Walt
slow_jun
Post by slow_jun »
Thanks Walt, for this... havent been here for awhile, but with this i will be staying... count me in for a couple of delrin and allu.
― Confucius
300D50
Post by 300D50 »
Well, had a little time yesterday, so one step closer to fixture being finished.
The next step is to get the models for the fixture and case mated together, and generate some toolpaths to punch holes for the 4-40's, locating dowels, and the initial hold down bolts.
I also have a few ideas on how to make things a bit easier this time, now that I'll have a rigid mount fixture instead of one that locates in a vice with parallels. 6 extra years of experience can do that, haha.
I'm tooled up for the most part, with the possible exception of one toolholder for the 1/8" endmill.
If I can stop myself from chasing geese, I'll make my goal of a first piece by the end of January.
I'm stoked this is coming together. You guys being supportive over all these years means a lot to me.
Walt
SnoopMaxx
Post by SnoopMaxx »
Awaiting updates :D
Happy New year Walt
Morten Max
klavy69
Moderator
Post by klavy69 »
300D50 wrote: 6 extra years of experience can do that.
Just means you have more dedication than most :wink:
300D50
Post by 300D50 »
Yay!
I'm becoming one of the borg! :lol:
Walt
300D50
Re: Discussion about possible aluminum transmission and parts
Post by 300D50 »
I ended up chasing an entire flock of geese. :roll:
The normal "Real Life" stuff got in the way.
Noticed the machine was out of tram, and out of level.
Floor settling/machine settling/having a building 40 feet from a crossfit location.
I swear, they must drop 300# weights. The entire floor shakes like in Jurassic Park. :shock:
Plopped the machine onto some 8' lengths of 3" x 3/8" angle iron to spread the load a bit more and re-leveled it.
Also needed to order some tooling/tool holders, so that happened.
When leveling the machine, found a leak in the spindle chiller loop. It's Dowfrost. I'm down a gallon. :cry:
Looks like Feb is the new goal.
Walt
300D50
Post by 300D50 »
Well, missed deadline again. :roll:
I did refill the chiller loop, so that's all taken care of.
Ordered a 384K memory expansion board for the machine last week, it came in Wednesday and I installed it after work. Feels good to have free space to fill with programs.
I ordered way cover wiper material yesterday, and did some more CAD work.
Updated to Autodesk Inventor 2018 Pro and HSM 2018 as well.
Baby steps.
Walt
