Discussion about possible aluminum transmission and parts
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: Discussion about possible aluminum transmission and part
Post by klavy69 »
count me in Walt! Good to see you haven't forgotten about us. Hope your machining is going as planned.
Are you thinkin just alloy this time around or are you going to do Delrin again?
300D50
Post by 300D50 »
Delrin and aluminum, same as before. I have a mailimg tube of white and black Delrin stock from the original production run still waiting. :)
The machine is coming in tomorrow, and it will be a while before I get fully situated.
Walt
Some people never have anything except ideas. Go do it.
klavy69
Moderator
Post by klavy69 »
cool again. I'll definitely be in for some delrin myself along with a blinger of aluminum!
if for nothing more as in sittin in a box waiting for the ambition to shift towards sitting indoors again working on my rc stuff :mrgreen:
Keep us posted.
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
klavy69 wrote:count me in Walt! Good to see you haven't forgotten about us. Hope your machining is going as planned.
Ditto
I too am very interested in the Delrin version. 8)
slow_jun
Post by slow_jun »
Delrin here.. and some Allu.. cant wait...
― Confucius
300D50
Post by 300D50 »
Press release time! 8)
Here are the facts right now.
  • I'm incorporated as ABC Prototyping LLC, so everything has come to fruition on that front.
  • The business is the proud second owner of a 1994 FADAL 4020HT VMC with a 15HP 10K RPM spindle and low (for the age) hours.
  • I have full control of the machine, no waiting for other people, no worrying about a job being cut short.
  • Shop overhead now has to be taken into account for future pricing, since my machine time is no longer "free", and there are bills to pay.
  • Reverse engineering any future parts will take longer, due to lack of a CMM, and a current lack of free time.
  • All my old reverse engineering data, CAD models, and CAM files from the 2.25 are still usable.
  • The machine does not have a probing system, so my fixtures will have to be redesigned.
On to the rest.
My plan is to do a limited re-release of the 2.25 cases, likely 10 each in white Delrin, black Delrin, and aluminum.
The first run will be aluminum, same as before.
Delrin bar stock is still 2.5X that of aluminum, but as before, I do not plan to charge any additional fee for the Delrin version.
Overall pricing will remain at $50 per case unless there are unforeseen circumstances.
The timeline for this is a bit open-ended, but if things go well I hope to have first piece by the end of January.
I'll also need to find a set of internals to make sure that the fits are correct, so if anyone knows a good place I can buy a set, please let me know. Most online vendors, to my eye, have the gears/diffs/etc out of stock.
Let me know what you guys think, and if there is anything I have forgot to cover.
It feels good to be able to say this WILL happen.
Walt
SnoopMaxx
Post by SnoopMaxx »
Big...Huge thumbs up :D
Morten Max
klavy69
Moderator
Post by klavy69 »
SnoopMaxx wrote:Big...Huge thumbs up :D
x2
will be picking up one of each delrin color and maybe an aluminum this time around...gotta have a blingey one :mrgreen:
300D50
Post by 300D50 »
Hey guys,
Can someone point me in the direction of where to buy a guts-kit for the 2.25, now that they are re-re'd? I can't seem to find the gears on the associated site... :roll:
Walt
SnoopMaxx
Post by SnoopMaxx »
Hey Walt
Now here's where you have to be careful.
There are 2 versions of the 2.25 diff case (You obviously already knew that )
However
Tower has most of the parts
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=stealth+
A-Main has a few of the remaining parts
https://www.amainhobbies.com/team-associated-rc10-replacement-parts-cars-trucks/c3104?fb=13
There's also the Stealth Transmission Kit No. 6560
But it's really hard to find sins it's bin discontinued
https://www.teamassociated.com/news/latest_products/1335-New_Stealth_Transmission_Kit_for_the_RC10/
Morten Max
300D50
Post by 300D50 »
I'm looking through those, and it looks like I'll need the following:
QTY Part# Desc.
1 LX2864 Associated Stealth Idler Shaft & Gear
1 LX2865 Associated Stealth Drive Gear Shaft Assembly
1 LXXH01 Associated Differential Assembly GT
I'll grab bearings from either VXB or McMaster-Carr, I've got the sizes from this post.
4ea. 3/8 x 3/16 x 1/8 unflanged.
2ea. 3/8 x 5/8 x 5/32
Am I on the right track?
Walt
SnoopMaxx
Post by SnoopMaxx »
1 LXXH01 Associated Differential Assembly GT is 2.60
you need the 2.25 diff
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2873&P=7
The out drives, diff rings and gear wont fit, the rest of the parts are the same in the 2.25, 2.4 and 2.6 diff
Morten Max
Has thanked: 1130 times
Been thanked: 3920 times
heres the list I use for the diff itself...
3926 Diff Rebuild kit (thrust bearings and washers kit, spring, T nut, bolt)
6577 RH Outdrive
6578 LH Outdrive
6580 Diff Gear
6581 Diff Balls
5/32 x 5/16 Bearings (2)
SnoopMaxx
Post by SnoopMaxx »
GoMachV wrote:heres the list I use for the diff itself...
6577 RH Outdrive
6578 LH Outdrive
6580 Diff Gear
6581 Diff Balls
So the TC3 diff has the same size diff rings as the 2.25 ? (Sweet, now I can get new diff parts for my TC3 :D )
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPA07&P=7
And here's the rest
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEDZB&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEDZC&P=7
Same gear I linked to
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2874&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD082&P=7
Morten Max
yes, and it comes with both the long and short T nut!
Users browsing this forum: No User AvatarGoogle Adsense [Bot], No User Avatarmikea96, User avatarTRX-1-3 and 4 guests
