Has thanked: 1080 times
Been thanked: 3729 times
Top are Maxxum FF fronts
Middle are turbo optima and newer rears
Bottom is turbo optima and newer front
Winger
Has thanked: 20 times
Post by Winger »
Thanks for the help on m last pile!
Here is another (more to come): http://postimg.org/image/8v9yksamj/
Winger
Post by Winger »
prp
Been thanked: 13 times
Post by prp »
Winger on the first pic
RC10L front ends,and the alu plate maybe for Frog Blackfoot.
On the second pic
The front bulkhead with bumper from Playtron Lynx
Some parts for the T Maxx arm bulkhead side
Phin
Has thanked: 82 times
Been thanked: 232 times
Post by Phin »
Also in the second link is a Bud's Racing transponder weight. The two wheels above it are Bolink drag car wheels that use rubber o-rings for tires. The smaller black circular piece below it looks like the top of a mechanical speed controller.
Fracek
Post by Fracek »
What is it ?
Phin
Post by Phin »
Kyosho/Robbe Sonic Sports
m_vice
Post by m_vice »
Got my hands on some old stuff and need help identifying some parts,
Any idea what these are for?
2015-03-19 18.56.43.jpg (160.54 KiB) Viewed 1918 times
2015-03-19 18.56.18.jpg (182.68 KiB) Viewed 1918 times
2015-03-19 20.38.29.jpg (150.63 KiB) Viewed 1918 times
2015-03-19 20.38.09.jpg (159.09 KiB) Viewed 1918 times
2015-03-19 18.52.38.jpg (140.36 KiB) Viewed 1918 times
2015-03-19 06.41.42.jpg (159.78 KiB) Viewed 1918 times
2015-03-19 06.41.35.jpg (175.53 KiB) Viewed 1918 times
The mrp part is a thrust bearing for their early pan car ball diff
dave00beer
Has thanked: 9 times
Post by dave00beer »
Picked this 1/12th Ferrari up, Was told it was made by Graupner, after doing some looking around the web I also seen one that was made by Cox. Does anyone know who made it forsure? Or was it a Graupner made car and sold in the states under the Cox name?
Thanks
Dave
Kyosho Laser, sold under the cox and graupner names as well....check here for a little more info...
http://www.rc10talk.com/viewtopic.php?f=30&t=37427
dave00beer
Thanks for the info gomachv 8)
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
I received this parts lot:
Parts I recognise:
- Kyosho Ultima rear gear box with layshaft and motor plate/cover
- Kysoho Optima rear gear box (belt drive?) + motor plate
- Kyosho Optima/Ultima limited slip layshaft
- Optima Mid front gear box
- Ultima C-hub
- The white thing is a modelling knife
- Some motor bit
The arms are also Kyosho I think, but for what car? And what are the other parts?
m_vice
Post by m_vice »
gomachv wrote:The mrp part is a thrust bearing for their early pan car ball diff
Nice, thank you sir.
Phin
Post by Phin »
EvolutionRevolution wrote:I received this parts lot:
Parts I recognise:
- Ultima C-hub
- Some motor bit
Ultima Pro-XL arms. Looks like the rear arm from a Frog too.
Squarish part between the two rear arms looks like the rear upper deck mount from an Optima Mid.
Return to “Identifications”
