- Has thanked: 1129 times
- Been thanked: 3919 times
Lots of tamiya king cab stuff there but I'll let others join in
I'll post up the pic so people don't get the same "infected" warnings I did
- Been thanked: 4 times
E: Tamiya Fox right front arm mount.
- Winger
- Has thanked: 20 times
- Been thanked: 5 times
Thanks for moving and re-posting the pics. Tried to post directly but it was too big. King cab makes sense as I have never seen them before. I did get a Fox somewhere so maybe that is where E came from.
A. is a Blackfoot rear body mount..
D. * Kingcab D6 part left upper suspension mount/shock tower bracket..
E. Fox part..
F & G. * Kingcab lower front suspension mount and arms.
H. Kingcab front body mount.
(* Kingcab and 58086 Toyota Hilux..)
E. Fox part..
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Okay I know what it is...it's a pan car cross brace that adds lateral springs to a t-bar car that uses damper discs. What I need help ID'ing is what car they actually go for because they're mislabeled and don't fit a 10L. Or a 12L/LW.
I'm thinking they may fit a 10L2 or 12L3 instead so I'm asking for help from somebody with either of those cars to check some measurements for me. I'm looking for the center to center distance of the two rear posts that mount the cross brace as well as the measurement for how far back those holes are from the center of the rear t-bar pivot screw hole.
The measurement for the Dillon cross brace holes are 127mm for the 2 holes furthest out and 100mm for the next two closer in towards center. These holes are 11mm and 10mm back from the center of the rear t-bar pivot.
Any help would be very much appreciated.
- Been thanked: 100 times
I don´t think it is for a 10L2. Have an original 10L2 brace here what looks same shape but measurements are different. The 2 holes furthest out are for body mounts and distance is about 152mm. Next two holes are for chassis standoffs, distance is about 127mm.
- Phin
Thanks for taking the time to measure.V12 wrote:I don´t think it is for a 10L2. Have an original 10L2 brace here what looks same shape but measurements are different. The 2 holes furthest out are for body mounts and distance is about 152mm. Next two holes are for chassis standoffs, distance is about 127mm.
The 127mm sounds good...how far back are the standoff holes from the center of the rear t-bar pivot? Could be the Dillon brace is for a 10L2 Oval which has the body mount holes to the inside of the chassis standoffs.
- Phin
Sounds about right. These probably fit the 10L2 oval and I suppose they'd also fit the 10L3 tourer and sport too. No reason to use them on the 10L3 oval though since that car has already got side shocks.
Thanks again for your time.
- Winger
Needed some parts from a lot and bought a lot of "I don't knows" too: http://postimg.org/image/a5wgrg42t/
Looks like some RC10 Servo mounts, antenna tube mount , a battery strap, but no idea on the rest. Appreciate any help. One of the A-arms says "Graphite."
The graphite arm and a couple around it are probably from the XXXT. It looks like some B4 front arms and either B4 or B44 rear arms in there as well.
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
On the right hand side, light blue bit is the end of a plastic motor holder.Winger wrote:Needed some parts from a lot and bought a lot of "I don't knows" too: http://postimg.org/image/a5wgrg42t/
Below that, the carbon-look plate with the red bit attached is a battery plate for a Nichimo Spirit FF, with part A11 attached. Looks to be some sort of pan car t-bar underneath it as well, probably goes with the long axle.
Very bottom (fibreglass part on top of metal part) is a Nichimo Spirit FF motor mount, with a radiator plate for the same car underneath.
- Phin
The short arm under the "graphite" arm is from an Ultima. The stub axle is from the front of an Optima. The top 2 arms are from a B4 and the arm just below them, on the left side of the pic, is from a RC10GT/T2.
The long rear axle looks like a 10L's....if it's non-magnetic it's probably Titanium. The long fiberglass piece under the 10L/pan car axle is the front suspension "beam" from a Parma Panther. The graphite t-bar is from a Panther too but don't recognize the piece of carbon fiber and red plastic part that's on top of it.
EDIT: If a magnet does stick to the pan car axle it might be for the Panther....I think they used steel axles.
Trying to figure out what these arms go to. My best guess is that the long top set are Yokomo YZ-10 front arms and the others are Optima (not sure which Optima) or Ultima rear and front arms. Am I close?
- 59 Replies
- 16059 Views
Last post by Diamond Dave
- 106 Replies
- 27090 Views
Last post by mikesofunny
- 431 Replies
- 54543 Views
Last post by Eccentric
- 67 Replies
- 16812 Views
Last post by bearrickster
- 321 Replies
- 41966 Views
Last post by tazz888
- 448 Replies
- 50088 Views
Last post by MelvinsArmy
- 351 Replies
- 47493 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
