- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Look like Bolinks that have been dyed orange.
Here's a set of whites: http://tinyurl.com/kszmhol
If you zoom in you can see they've got the same dimples around the bearing holes.
- Has thanked: 1129 times
- Been thanked: 3919 times
- Phin
A good example of why the space aliens, with their super-advanced knowledge and technology, think the human race is not worth making contact with.gomachv wrote:Well... What is it?![]()
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
That looks like a rare A$$-o'ciated RC-10LBBQ offroad pancar racer.
Congrat$!
Congrat$!
It looked too cool to pass up... What does it fit lol!
There were some electric conversions for rc250 made bitd.....and this looks overbuilt for a 1/12 or 1/10....
- Phin
I saw that but had no idea what it was for either. Looks too long to be a 1/12 or 1/10 pan car rear pod but it also seems a little too narrow for an RC250 doesn't it? I was guessing maybe an early drag racer.
I couldn't figure out the weld line down the middle (if that's what it is). Thinking maybe it's cast aluminum or magnesium since a machined part one could've been done in one piece. Unless it was wider for the RC250 and someone handy cut it and skinnied it up.
that was probably made with two pieces of angle aluminum, then welded together. Much less work than to machine down a huge block of aluminum. I know because that's how I would do it
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
I would've just bought it from one of you guys after you did all the work
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
Phin wrote:I would've made it in 3 pieces and just used screws.
I heard you were afraid of screwing things yourself....klavy69 wrote:I would've just bought it from one of you guys after you did all the work![]()
- LTO_Dave
- Has thanked: 52 times
- Been thanked: 287 times
I've had these diff parts for years and have no idea what any of them fit:
The top middle outdrive(threaded inside the shaft part) fits inside the top left outdrive, but they're different width drive cup areas.
The piece on the top right is a sprocket held on with setscrews that are stripped so I can get it off. The inside of the top shaft portion is threaded.
The bottom left outdrive fits inside the middle diff half and is held in place with a setscrew. But the bottom left outdrive is shorter than the other one and doesn't have a flat spot.
Top two on the left are kyosho
Still racking brain on the rest....
- 59 Replies
- 16059 Views
Last post by Diamond Dave
- 106 Replies
- 27090 Views
Last post by mikesofunny
- 431 Replies
- 54556 Views
Last post by Eccentric
- 67 Replies
- 16812 Views
Last post by bearrickster
- 321 Replies
- 41974 Views
Last post by tazz888
- 448 Replies
- 50093 Views
Last post by MelvinsArmy
- 351 Replies
- 47504 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
