NIX91 Questions and Answers
Moderator: Seabass
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Re: NIX91 Questions and Answers
Post by Asso_man! »
Any ideas about where the gold wing mounts come from on Masami's car? Never seen these before.
Come and visit the stable
Minisforever
Post by Minisforever »
Asso_ man been searching for the same. Here's what I came up with so far. Looks to be a yokomo part from the the later 834b. Part number ZC-107h but looks like there was a production change on part as some point. PM me if you come up with any leads and I will do the same.
http://www.rc10talk.com/viewtopic.php?f=29&t=24261
Asso_man!
Post by Asso_man! »
OK thanks, that's where I saw them once. According to teh thread you mention they should be part number ZD-107H, specific wing buttons for the WCS. Not easy to find I guess...
Peakey
Post by Peakey »
Are these the rear wheels I need ?
Minisforever
Wheels look right, but it's always hard to tell by photo. Header card on wheels say 12mm offset. Hope that helps
Asso_man!
Post by Asso_man! »
Peakey wrote:Are these the rear wheels I need ?
These are probably 2.2" where 2.1" were used in '91. The ones on Masami's car are the ROAR ones and have 4 holes in the middle. He also trimmed the outside lips (inner and outer) to get more side grip and lightened them with quite a lot of holes. Pics can be seen in the RC10 buggy forum sticky thread.
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
Asso_man! wrote:OK thanks, that's where I saw them once. According to teh thread you mention they should be part number ZD-107H, specific wing buttons for the WCS. Not easy to find I guess...
Definitely the ZD-107H part number in websteves link, though there are picture's also showing these ZC-107H on his older 4wd. :lol:
Minisforever
Seriously Aaron is there a yokomo part you don't have? :lol:
Check link out, maybe I'm confused on part number :?
I figured eventually I would have to cough up some big bucks and have them machined. Hey, If enough guys need these wing buttons maybe we can have a small batch machined and anodized?
Been thanked: 3919 times
I just got a text message from Kelly, he wants me to test fit the stealth buckles and pins to make sure they are 100%. He said actual part numbers will then be assigned so no more trying to explain what you are looking for. I'll update soon
Asso_man!
Post by Asso_man! »
Definitely the ZD-107H part number in websteves link, though there are picture's also showing the ZC-107H on his older 4wd. :lol:
These are not the ones shown here: http://www.rc10talk.com/viewtopic.php?f=35&t=5500&start=105
They are gold as well but much taller with a extra basis at the top.
Could it be that you don't have that part? Lol
aip47-2008
Agreed!
ralphee
Post by ralphee »
Now thats cheap!
Lee
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
I´ve got the zc-107h version and they seem to have a bigger diameter than the ones on Websteves Stealth pictures.
The ZD´s You´ve linked to, seem to have the same diameter as my ZC´s, ergo too big on the "shaft" part?
Mine could be 5,4 mm on the "shaft" part - the ones on the Stealth pictures could be 1mm thinner?
The lower part angled finish on the Stealth pictures seems to be different too?
Running changes in production?
Gone fishing
Minisforever
Dennis at first I thought it could be just an optical illusion but I think your right. I just compared the two and the cylinder portion is defiantly a smaller diameter. Good eye Dennis
Return to “CNCrc”
