My first RC10 Gold pan -- PLEASE tell me what I've got
Has thanked: 270 times
Been thanked: 2095 times
Re: My first RC10 Gold pan -- PLEASE tell me what I've got
Probably easier to buy a $20 Hobbywing 1060 esc.
68lemans462
Has thanked: 4 times
Post by 68lemans462 »
Is there a tire/wheel combo for all 4 that is commonly available? Any links? I'm having trouble piecing together the wheels/tires front/rear for running around in dirt/pavement with this thing.. Local hobby shop couldnt help, but they did help me with pinion gear and other stuff..
...and thanks for all the help. You guys are awesome. Also ordered the more modern ESC as recommended.
Has thanked: 2607 times
Been thanked: 2981 times
Does it still have the 1/4" rear axles? JConcepts has rear wheels to fit them:
https://www.amainhobbies.com/search?cID=&s=JConcepts+3359
Matching fronts:
https://www.amainhobbies.com/search?cID=&s=jconcepts+3358
If you have the newer 3/16" rear axles, there are these mono wheels that will have more tire choices:
https://www.amainhobbies.com/search?cID=&s=jconcepts+3404
Matching fronts:
https://www.amainhobbies.com/search?cID=&s=jconcepts+3403
With these front and rear mono wheels, these tire combos fit:
Schumacher 6595/6596 full spike off-road tires
Schumacher 6709/6710 RT1 on-road tires
For foam inserts, I used Schumacher front U6652 foam inserts and rear U6653 foam inserts.
If you're interested in converting to 3/16" rear axles, this is a CVD option:
https://www.amainhobbies.com/custom-works-short-cvd-kit-2-csw7210/p1274912
The tires for the 1.9/1.7 JConcepts can be hard to find at times.
They are overseas but JC Racing has wheel options for both axle sizes.
Alternatively, you can use the above 2.2 JConcepts fronts and Traxxas 7171 rears with Factory Works rear hexes. I have this setup on two of my cars.
Users browsing this forum: No User AvatarGoogle [Bot], No User AvatarGoogle Adsense [Bot], No User AvatarTbot [Bot] and 8 guests
