I do have now a model which allows me to play with the internal diameter of the tyre I want to put on the rim, the width of the rim, and the number of spokes. The spoke will enlarge with the diameter and will reduce when the number of the spokes increases. This may still require some fine tuning to find the right proportion, but at least it's a start. I still need to find a way to add rings for the modern tires, and as well some différent possibilities for the driver (which is currently a friction based driver, but it would be better to allow for an ex driver in some cases...
Here is a sample of the possibilities at this stage, for the front wheel...
I still need to take care of the rear wheel properly (but I have to redo it fully as I completely messed up my initial project doing so beginner's mistakes, and secondly because the hub driver needs more thinking to be able to handle an hex driver (not for the Samurai, but for other purposes)
