Do old radios and receivers hold any value to anyone?
- NWarty
- Has thanked: 23 times
- Been thanked: 21 times
Re: Do old radios and receivers hold any value to anyone?
All of vintage restorations have period gear.
I'm still on the look out for a decent Airtronics XL2P. Both of mine have spontaneously combusted due to faulty battery holders.
The Magnum Jr., XL2P, and MX-3 are my favorite radios of all time.
A bit different
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2980 times
Most of the 4+ channel radios I see are 72mhz and labelled to be used for aircraft only. One I came across says it's a 72mhz radio with a 75mhz crystal in it. Does that work for surface vehicles? Is there a good reason not to use 72mhz for surface vehicles? Maybe that's just to not mess up flying RCs by stepping on their frequencies.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2095 times
I see 27mhz 4 channels pop up occasionally.
- Frankentruck
If 75mhz crystals really do work as a system in 72mhz radios, that opens up my collection of crystals and receivers to new possibilities.
My son is thinking he'd like us to do a battle bot someday and there would be baby steps along the way. The 'use what ya got' kind of baby steps.
- MadZero
- Has thanked: 33 times
- Been thanked: 15 times
It’s a yes from me, all my vintage 1/8 have period radio. Futaba FP-2F steerwheel is probably my favourite because it’s so out there l but I also have a soft spot for the MRC 772 & Sanwa GC2200 systems, personal nostalgia thing basically. The modern(ish) stuff I run all get told what to do by a Sanwa MT-44, impressive bit of kit & gets the job done in a soulless plasticky way.
old glow engines make me happy
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
I grew up with Airtronics stick radios, then to pistol Magnum sports and jr.s....Jr's being oh so classic....but my all time favorite vintage transmitter is the Airtronics M8, partially because Thumbs got one for Xmas one yr (probably 96'ish) when I had fallen out of rc and he was still in it hard-core, and secondly because I bought a TC5 used, that came with a M8, and found out just how righteous it was!
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Do you have the charger for your M8, and could you please take a picture of the label on the charger that lists voltage, plug polarity, etc.?coxbros1 wrote: ↑Mon Dec 27, 2021 8:51 pm I grew up with Airtronics stick radios, then to pistol Magnum sports and jr.s....Jr's being oh so classic....but my all time favorite vintage transmitter is the Airtronics M8, partially because Thumbs got one for Xmas one yr (probably 96'ish) when I had fallen out of rc and he was still in it hard-core, and secondly because I bought a TC5 used, that came with a M8, and found out just how righteous it was!
Some years ago I received a Sanwa M8 that sadly lacked the charger, and the manual that I found online has no specifications for the charger.
- coxbros1
Sadly, I don't have any of it anymore, but Thumbs on here might
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
I still have the radio somewhere. I didn't have a charger with mine. Just took AAs. You may be able to use a universal one. They have different size inserts and they are based on voltage I think. I bought one for an old electronic dart board with no cord and it works well. Something like this. May find one cheaper. First I saw.
[Upgraded Version] SoulBay Universal AC/DC Adapter Multi-Voltage Regulated Switching Power Supply with 8 Selectable Adapter Plugs, for 3V to 12V Home Electronics, 2Amps Max https://www.amazon.com/dp/B01N2K48HR/ref=cm_sw_r_apan_glt_fabc_N0QDTP0K49S8PGPFJ68A
- coxbros1
That should work!
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
I am a big fan of the Caliber radios from Airtronics. I feel lucky to have found these 3 examples in new condition. These radios feel so good in your hand.
Their quality is comparable to my modern Futaba 7PXR.
Sure, but I don't know the polarity of the plug I need. It isn't marked on the transmitter.THEYTOOKMYTHUMB wrote: ↑Tue Dec 28, 2021 7:58 pm I still have the radio somewhere. I didn't have a charger with mine. Just took AAs. You may be able to use a universal one. They have different size inserts and they are based on voltage I think. I bought one for an old electronic dart board with no cord and it works well. Something like this. May find one cheaper. First I saw.
I guess I could try measuring whatever charge is still in the battery, I guess...
- THEYTOOKMYTHUMB
I don't know much about that. Derek may know.EvolutionRevolution wrote: ↑Sat Jan 01, 2022 1:59 pmSure, but I don't know the polarity of the plug I need. It isn't marked on the transmitter.THEYTOOKMYTHUMB wrote: ↑Tue Dec 28, 2021 7:58 pm I still have the radio somewhere. I didn't have a charger with mine. Just took AAs. You may be able to use a universal one. They have different size inserts and they are based on voltage I think. I bought one for an old electronic dart board with no cord and it works well. Something like this. May find one cheaper. First I saw.
- coxbros1
Actually I am not sure either....looks like testing it with what charge is left to determine polarity is your best option
- Frankentruck
The standard convention is center/tip is positive. However, maybe something like this would help.
- 1671 Views
- 703 Views
Last post by damian
- 696 Views
- 759 Views
Last post by aconsola
- 1199 Views
Last post by urban hype
- 2336 Views
Last post by ljh501
- 2385 Views
Last post by V12
- 636 Views
Last post by sneako43
