Headling’s RC10 no5, Willspeed special!
Headling
Has thanked: 25 times
Been thanked: 29 times
Re: Headling’s RC10 no5, Willspeed special!
Post by Headling »
Made a start on it and the front ends pretty much done now
Added one of my nose weights I make to the car, looks bling and will be a great addition for the Astro/carpet racing I do
If in doubt go flat out!
Headling
Post by Headling »
Back end is back in with the B4.1 geared box fitted
Looking forward to trying this on carpet and not wrecking stealth ball diffs
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
Very nice indeed! Looks great. 8)
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
Headling wrote: Tue Sep 01, 2020 8:27 am Here is the car, fitted a longer front tower as the B4 shocks are longer than the stock team shocks
Part of the problem here is that you used long Andy’s front arms which were designed before the AE long front arms and are supposed to work with the smaller 0,56 shocks and stock/original shock tower.
Come and visit the stable
Headling
Post by Headling »
Thanks, it’s working ok now with the taller tower but it would be better with some other front arms on it
I may check thingiverse out or klein arms perhaps
Has thanked: 268 times
Been thanked: 2094 times
Headling wrote: Tue Oct 13, 2020 7:17 am Thanks, it’s working ok now with the taller tower but it would be better with some other front arms on it
CE or Worlds arms would be a more direct fit. RPM arms fit as well but have gotten a little pricey.
The Klein arms are for the 10T style nose and bulkhead. I'm actually getting ready to order a set.
Headling
Post by Headling »
Ah ok cheers, yes got a couple of rpm sets on my other RC10’s
Shame no one makes dynotech style arms from delrin in the normal worlds dimensions for the stock nose/front end
XLR8
Post by XLR8 »
Headling wrote: Tue Oct 13, 2020 5:43 pm Ah ok cheers, yes got a couple of rpm sets on my other RC10’s
As it happens, I've been spending time the past couple days researching WOIN in preparation to build one for myself. I'm planning to make my front and rear arms so I have a slab of 8mm delrin in the post headed my way. I just read your comment which has prompted a couple questions.
So you're describing an AE worlds (or CE) arm ("normal worlds dimensions for the stock nose") but in delrin or do you say "dynotech style" because they include some additional design feature not included with the AE arm? Maybe accommodation for B4 wheel and/or improved shock mount locations perhaps?
I've never actually held Dynotech arms, only seen photos, so I'm trying to fully comprehend the differences between them, AE, Andy's and RPM arms.
I have found this post which is extremely helpful
https://www.rc10talk.com/viewtopic.php?f=35&t=27885&start=15
Headling
Post by Headling »
Hi Doug, my comment was based around make some front arms similar to the rpm arms out of delrin, I like the rpm front arms as they have more shock positions than the Worlds front arms
Look forward to seeing what you knock up out of your delrin
Headling
Post by Headling »
So the car had a bit of a gap between the chassis and the gearbox so made up this lexan cover piece up and bent it up with a heat gun, finishes off the rear end
Headling
Post by Headling »
Fitted up some rear wing mounts and drilled the tower, i ended up using kyosho zx6 wing mounts as had a set in the box
Headling
Post by Headling »
Installed the radio gear, just need to mount up some tyres and sort a body shell out and we are done
Users browsing this forum: No User AvatarSemrush [Bot] and 6 guests
