870c to 91 works build
mikea96
Has thanked: 659 times
Been thanked: 878 times
Re: 870c project
Post by mikea96 »
I think I'm just going to change the arms to works arms so I can use the zc422 universals I have.
Re: 870c project
Yeah, the wide kit use the outer hole on the front arm and had a very thin wheel hub. The track width wasn't changed, but the pivot points were moved out.
mikea96
Re: 870c project
Post by mikea96 »
Yeah I played around with that a bunch and I figured since I bought a fiberlyte works 91 chassis set I will just make it look like a works 91.
mikea96
Re: 870c project
Post by mikea96 »
Ok so what is a good replacement rear upright for a 91 works?
Re: 870c project
I think 91 was updated to 93 style moving forward. Also used on yr4 series cars, so mid production yr4 should get you the parts you need
mikea96
Re: 870c project
Post by mikea96 »
Perfect thanks!
mikea96
Re: 870c project
Post by mikea96 »
Big updates coming on this one! Works arms, aluminum bulkheads, tcs unit, titanium turnbuckles. 8)
Spoon
Re: 870c project
Post by Spoon »
mikea96 wrote: Mon Nov 04, 2019 9:49 pm Big updates coming on this one! Works arms, aluminum bulkheads, tcs unit, titanium turnbuckles. 8)
Subscribed
mikea96
Re: 870c project
Post by mikea96 »
Fine pitch belt system on it's way as well. I have been trying to whiten the yellowed bulkhead caps but it doesn't seem to be working so I think I will just paint these ones.
Spoon
Re: 870c project
Post by Spoon »
mikea96 wrote: Sat Nov 09, 2019 12:03 am Fine pitch belt system on it's way as well. I have been trying to whiten the yellowed bulkhead caps but it doesn't seem to be working so I think I will just paint these ones.
I just whitened my motor mount cap, took about 10 days in hydrogen peroxide. It never came out Snow White but it did take out a huge yellow discoloration and a few shades.
mikea96
Re: 870c to 91 works build
Post by mikea96 »
I'm going to try and dye the bulkhead caps today with just hot tap water. Has anyone had luck doing this without ruining them?
I've never heard of someone being successful with it
You will warp them.
Just noticed the hot "tap" water. That shouldn't warp them, but doubt they will take color.
mikea96
Post by mikea96 »
Ok guess I'm painting them today.
Return to “Yokomo Forum”
