Just dug this out of a box...
tamiyadan
Been thanked: 6 times
Re: Just dug this out of a box...
Post by tamiyadan »
shodog
Been thanked: 91 times
Post by shodog »
I use wd-40 for removing sticky goop off of bodies. It’s safe for plastic and paint. For degreasing gears I use mineral spirits
Those wheels look cool but they are really junk. The gold plastic is super brittle and eventually you will break them if you run them. Keep those wheels for the shelf and get a set of staggered kawadas or vaterra wheels if you plan to run it.
Kawada
Vaterra
Vdubber
Post by Vdubber »
Thanks. Those are super clean. I'll check them out.
Did the bearings last night.
Vdubber
Post by Vdubber »
I know what you mean about the brittleness. The wheels that came on it are broken and I only drove this a few times when I was a kid.
Are the Vaterra's 54x30 and 54x26? Are they 2 piece so the center color can be changed?
Vdubber
Post by Vdubber »
Little bit off on chassis fitment
shodog
Post by shodog »
The Vaterra wheels are one piece. To paint the centers you have to carefully tape off the chrome rim. They do come in a couple of colors
Vdubber
Post by Vdubber »
Ok thank you.
Looks like I am going to have to fill and move the holes on the body :roll:
tamiyadan
Post by tamiyadan »
Vdubber
Post by Vdubber »
The wheels dont line up with the wheel wells. When I turn the fronts they hit the fender.
Vdubber
Post by Vdubber »
Original part...didn't fix the fitment.
Vdubber
Post by Vdubber »
Here is a better view of the problem
tamiyadan
Post by tamiyadan »
Vdubber
Post by Vdubber »
Life saver! I'll order that up as soon as I can. Much appreciated. Getting closer...
Found out I need a new battery for my 1980s Futaba Magnum also...this is getting out of hand :lol:
tamiyadan
Post by tamiyadan »
Vdubber
Post by Vdubber »
Looks like they got rid of the L shaped rear mounts and moved the entire assembly back some
Return to “Tamiya Forum”
