RC10 - FF10 -Done-
sandkil
Has thanked: 782 times
Been thanked: 585 times
Re: RC10 FF
Post by sandkil »
NomadRacer wrote: Wed Oct 03, 2018 7:00 pm Would, say, a 2mm hinge pin from a AE RC12R5.2 work?
That would have worked if it had the lengt of front inner hinge pin. If the length is correct I would have to fabricate new arms as they are allready drilled for std hinge pins. The "quick fix" is ball links.
I don't know if the Dubro plastic links are strong enough though and come to think of it.. hmmm.... these Dubro 3365 might not work as you want a upwards/inward travle of the rear wheels when compressing the suspension.
Looking at the Kanda/Ryuz the inner hinge of the arm is shorter then the outer.
I think it's back to the drawing board for my part.
NomadRacer
Has thanked: 81 times
Been thanked: 79 times
Re: RC10 FF
Post by NomadRacer »
Bummer :? If they would have worked, I'd have sent you some.
Bum on Direct Deposit
sandkil
Re: RC10 FF
Post by sandkil »
NomadRacer wrote: Thu Oct 04, 2018 5:37 am Bummer :? If they would have worked, I'd have sent you some.
Thanks man :wink:
limestang
Has thanked: 91 times
Been thanked: 249 times
Re: RC10 FF
Post by limestang »
Where did this project end up?
- limestang
Marshky
Been thanked: 13 times
Re: RC10 FF
Post by Marshky »
Finally I found the progress. Saw the last update on Instagram a while ago. Have been waiting to see how it would turned out. How is it going?
sandkil
Re: RC10 FF
Post by sandkil »
It's tucked in a drawer....
I guess I need to dust it off and solve rear end suspension issues :lol:
sandkil
Re: RC10 FF
Post by sandkil »
Time to blow of the dust.
Still alot of question marks to straighten out.
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: RC10 FF
Post by Mr. ED »
you can do it; I believe in you
sandkil
Re: RC10 FF
Post by sandkil »
Fabricated the front shock tower (Probably not the final version) Decided to move it rearward so it could bolt on the bulkhead.
On the pic it’s 1.32” rear shocks, but will have to source 1.02” as these are way too long!!
Asso_man!
Has thanked: 40 times
Been thanked: 81 times
Re: RC10 FF
Post by Asso_man! »
You could use a taller shock tower and play with inner spacers for the right suspension travel?
Come and visit the stable
sandkil
Re: RC10 FF
Post by sandkil »
Asso_man! wrote: Fri Oct 16, 2020 5:00 am You could use a taller shock tower and play with inner spacers for the right suspension travel?
Yeah, that might be the way to go in the end if nothing else.
I just wanted to have as low fron end as possible. The body will sit behind the bulkhead and I think it will look even more weird with tall shocks and towers.
sandkil
Re: RC10 FF
Post by sandkil »
Shocks done. Just need to add oil 😀
At the front I’m going for 1.02 shocks and 0.71 at the rear with Du-Bro ball ends to clear the trailing arms.
All shocks have RPM spring cups for clearance and no internal limiters. Oil will initially be 35wt.
sandkil
Re: RC10 FF
Post by sandkil »
My brain is hurting...
Need your help on steering set up (only mockup at the moment).
I think shorty Lipo is the only option..
With trailing arms you get different movement depending where the inner ball joints is located on the chassis.
There will be a top deck with spacers on rear arm mounts.
Any input on this geometry is greatly appreciated.
Sorry for messy pic.
Has thanked: 1079 times
Been thanked: 3719 times
Re: RC10 FF
If it were mine...assuming it would clear, I would swap bellcranks leaving the "input" side on the right. Servo can then mount alongside the pack like the original prototype RC10.
Factory Works website
sandkil
Re: RC10 FF
Post by sandkil »
GoMachV wrote: Thu Oct 29, 2020 12:53 pm If it were mine...assuming it would clear, I would swap bellcranks leaving the "input" side on the right. Servo can then mount alongside the pack like the original prototype RC10.
That’s a good idea. Thank you.
With the B4 servo link it will clear. I will have to widen the openings in the pan for maximum steering throw, but that was something I knew from the beginning.
Users browsing this forum: No registered users and 14 guests
