Wheel base RC10CE vs Worlds Car
Re: Wheel base RC10CE vs Worlds Car
Thanks for the info! A couple of questions:
- how would the b3 hub help? Is it set out further than the world’s hub? Hence allowing more room for 9754 cva?
- I think I know what droop is I assume it’s how low you set your shocks
- limiters on shocks? What does this mean.
Thx!
Thx!
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
My......ocd.....compels me..
It's track width.
It's track width.
- Been thanked: 43 times
>TRX-1-3
Thank you for your correction. I agree that "rear tread" is wrong.
>BACK_AT_IT
I tried the "CVA axle > B3 hub > B4 blue wheel spacer > drive shaft pin > Custom works 1/8 spacer > worlds tire" combo. Here the CVA bone is #9760. B3 hub has inward offset so that #9760 can work as CVA bone with enough droop.
However, it does not work because the custom works 1/8 inch spacer does not fit to the worlds tire.
It hits the side edges of the tire shown by red arrows. I am sorry.
>BACK_AT_IT
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
so would the simple removing of the outerside edge of the circle of the worlds wheel with a dremel work or am I reading too much into this?
Yeah slight tweak on the wheel slots and you are golden. Don't be sorry, this looks like it will.work nicely if you have enough thread engagement on the nut.
The B3 hub (and I even found a set at my local hobby shop) looks like it will work with the original Worlds Car CVAs. I can see that I won't need to have extreme camber or limit my droop a lot with these hubs.
Thanks for your help everyone!
- Has thanked: 9 times
- Been thanked: 9 times
Or if the setup will be used with a lot of wheels, file/dremel off the ends of the ridge on the spacer so it fits into the wheel
- Has thanked: 307 times
- Been thanked: 5 times
How much longer would you extend the outdrives? 1/4" or 1/8" ?mk-Zero wrote: ↑Sat Sep 02, 2017 7:27 pm If you have that blue anodized cone-shaped washer that comes with the Worlds CVA conversion kit put that inboard and maybe like 2 of the 3 thin washers, then put the 3rd outboard. Annoying that you have to do this, but works like a charm.
I need to make those extended length outdrives to solve this issue.
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 21 times
Probably about 1/8", that would solve the issue.guitronics wrote: ↑Sun Aug 25, 2019 10:49 pmHow much longer would you extend the outdrives? 1/4" or 1/8" ?mk-Zero wrote: ↑Sat Sep 02, 2017 7:27 pm If you have that blue anodized cone-shaped washer that comes with the Worlds CVA conversion kit put that inboard and maybe like 2 of the 3 thin washers, then put the 3rd outboard. Annoying that you have to do this, but works like a charm.
- 1010 Views
Last post by BACK_AT_IT
- 244 Views
Last post by jcwrks
- 2086 Views
Last post by XLR8
- 3552 Views
- 657 Views
Last post by knucklebuster
- 3730 Views
Last post by Trass
- 1809 Views
Last post by dinglem
- 1155 Views
Last post by rctenracer
Users browsing this forum: curl [Bot],
howsyouraspen and 3 guests
