Time to pass on the collection. NOT!
- PlastiZapCA+
Re: Time to pass on the collection. NOT!
RC104ever wrote:I know how you feel! I have been spending all my time with my new R3 and the RC stuff has literally been gathering dust. I would like to thin the herd a bit or sell off some of the valuable / rare bits but I can't quite bring myself to do it yet.
Like I was told, you'll regret it. I sort of miss the few bits I've sold even though I wasn't doing anything with them.
- PlastiZapCA+
Phin wrote:Very slick but I'd lose the MSC and save room by using a micro-switch. Or better yet go with a small nitro engine.
I was thinking about just showing the mechanical components instead of trying to hide it. I like the way a good old fashioned speed control looks when it's being throttled, sort of like the linkage on a carburetor. Although I do want it to run it will be more of an art piece. We'll see how it comes about. I've started making a list of stuff to order from Tower Hobbies. Going to need lots of brass tubing and solder.
- PlastiZapCA+
Wait a second! A nitro engine, then I could put a fuel tank on the front of it. What size would be good for something like this? It would probably flip with my luck.Phin wrote:Very slick but I'd lose the MSC and save room by using a micro-switch. Or better yet go with a small nitro engine.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
That, I've got no advice on. It's only recently that I started thinking about building a couple of fuel burners so I know very little about them.PlastiZapCA+ wrote:What size would be good for something like this?
depending on how set you are on that rear axle, you could use a b44 diff assembly, and run the nitro engine north south. instead of drive cups, machine some axles that fit as the outdrives with some wheel adapters clamped/set screwed on. then the back end would be held up with the diff case.
- PlastiZapCA+
This all sounds complicated, I think I'll stick with electric.
This way I can actually build it instead of thinking about it.
- Has thanked: 100 times
- Been thanked: 205 times
That's probably good.... if you went nitro you woulda had to find a nice supercharger for the engine for extra realism points lol
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- 1052 Views
Last post by radioactivity
- 754 Views
Last post by airdreams1
- 54 Replies
- 8163 Views
Last post by GeneralZod
- 27 Replies
- 3928 Views
Last post by Bugle
- 24 Replies
- 5511 Views
Last post by mk-Zero
- 1586 Views
Last post by Carknowledge101
- 1260 Views
Last post by Minisforever
- 1300 Views
Last post by TRX-1-3
