Tomas TRX-1 Vintage race machine:)
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: Tomas TRX-1 Vintage race machine:)
Post by Mr. ED »
jwscab wrote:after posting that link, and looking around, those are readily available in many places, as it was used on a bunch of traxxas vehicles. so you should be able to find a set with more reasonable shipping, for sure.
http://www.liquidrc.com/index.php?main_page=product_info&cPath=0&products_id=52022&zenid=4lqk8id44k0vef847124clfoi7
1$ for shipping, 5 $ for the parts ;) the way it should be
Tomas Karlsson
Post by Tomas Karlsson »
So on to the next issue!
My front arms did broke today when testing the car, i guess they had dried out thru all thoose years.
I am looking for replacement arms, is there any newer traxxas models that fits or do i need to find TRX-1 arms?
Happy as always for answers!
Mr. ED
Post by Mr. ED »
No help there, though you may try liquid rc with the original part nr: they have some old stock.
I broke 2 rear blue eagle rear arms that came of the same car, with only a couple runs between them. Then I put 2 others on from another donor car, and they are both still good countless runs later. A lot depends on where you get your parts from: warm dry places = bad. It helps to boil the parts; the nylon takes up moist and becomes more flexible again.
Or put them in the dishwasher ;)
Tomas Karlsson
Thanks for the input, really need to sort this stuff out.
Mayne i try the bandit front arms to see if they will fit.
Mr. ED
Post by Mr. ED »
I have seen rc10's with traxxas front arms, maybe it works the other way around too?
The RPM ones look good, but might not go well together with the overall styling of your car:
http://www.liquidrc.com/index.php?main_page=product_info&cPath=0&products_id=33048
TRX-1-3
Has thanked: 2067 times
Been thanked: 992 times
Post by TRX-1-3 »
For what it is worth, TRX-3 front arms will fit, although, you need to run the lower shock spacers that come with them and they will reduce the front track width by approximately 1.5cm or so. And there will be some turnbuckle math involved as well. Those are 2631R arms for TRX-3/TCP.
Mark
Mr. ED
Post by Mr. ED »
TRX-1-3 wrote:For what it is worth, TRX-3 front arms will fit, although, you need to run the lower shock spacers that come with them and they will reduce the front track width by approximately 1.5cm or so. And there will be some turnbuckle math involved as well. Those are 2631R arms for TRX-3/TCP.
Mark
Don't they cause problems with the shocks? I think the mounting point is too far back or forward.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
Mr. ED wrote:I have seen rc10's with traxxas front arms, maybe it works the other way around too?
yes I have a trx1 with widetrack AE arms... the track is still too narrow though.
boil your parts before running them the next time around!
Paul
Mr. ED
Post by Mr. ED »
Maybe if you use the C-carriers and knuckle for hex rims : as on the current bandit, the track gets a bit wider again?
TRX-1-3
Post by TRX-1-3 »
Mark
Negative. TRX-3 arms have the wide shock slot and run that aluminum spacer. You can put TRX-3 arms on a TRX-1 but TRX-1arms won't fit a TRX-3 without offsetting the shock tower or modding a Rustler / Bandit front bulkhead.
Mark
Tomas Karlsson
I have decided to go with a customised project regarding the front arms, i will give you guys some pics next week or so when the new arms are milled and ready to be fitted.
Tomas Karlsson
Done by a friend!
Lonestar
Post by Lonestar »
Wow! :shock: Delrin?
Tomas Karlsson
Just regular nylon.
I think this will hold up really well:)
Lonestar
Post by Lonestar »
Tomas Karlsson wrote:Just regular nylon.
No reason why it wouldn't ;) All you need now is matching rears :D
that's super cool!
Return to “Traxxas Forum”
