Rc10L cleanup
FullThrottleTXOutlaw
Re: Rc10L cleanup
Post by FullThrottleTXOutlaw »
marlo wrote:Great work! how did you get the very thin black lines around the doors, and rear clip on the Rothmans car?
Pactra used to make this great stuff called line and trim tape or something along those lines.
Google image, this stuff; Works great, it's okay with curves, adheres well, but it's just hard to find now or at least it was a couple months ago.
This isn't the best example, but I did the lines on this 20+ year old body with "Graphic Chart Tape" from Amazon - I ordered 1/64" but 1/32" is what showed up. It was only $5 or $6 so I figured might as well use it.
The Graphic Chart Tape doesn't adhere as well nor does it curve/bend as well, but that could just be the particular brand I ended up with. Applying heat helped with that though.
The narrowest lines on this body were done with 1/64"
Re: Rc10L cleanup
FullThrottleTXOutlaw wrote:Pactra used to make this great stuff called line and trim tape or something along those lines.
I think I have a few of those little canister tapes lying around. Never actually used them, if I recall correctly.
marlo
Has thanked: 18 times
Been thanked: 22 times
Re: Rc10L cleanup
Post by marlo »
Great info, Thank you!, I'll look into that.
Users browsing this forum: No User AvatarAhrefs [Bot] and 3 guests
