http://i1074.photobucket.com/albums/w409/UUphonebox/Mobile%20Uploads/0628142229_zps68865939.jpg
But I will need to remember to get some tires before it gets too close!
Also, what timing system is run? Would the newest Mylaps RC4 'ponders work?
Erich Reichert wrote:Not really sure about that one. We just all run as soft as possible. Some guys shave tires and yes their faster for it but its totally up to you.
Ok, thanks. That really helps. I bought PL Holeshots M3/soft compound w/ inserts for the outdoor track last year but ended up not being able to make it to the race so to keep it simple and inexpensive I'll probably just use them this year as you described. How does qualifying work? Does each racer go individually?Mark Westerfield wrote:When I run there, I have a set of Pro-line Holeshot 2.0 in M4 compound, Jconcepts And-1 inserts for practice time when the track is not swept, for racing when the track is swept I use Pro-line Scrubs(f)/Suburbs(r) in M4 compound, with stock inserts(f)/AKA red inserts(r) with Sticky Kicks red traction compound.
Reinaldo,
Jconcepts blue and green compound is just not as fast as Pro-line M4 compound at Wolcott. I've never tried M3 compound at the track so I can't tell you on those. I like Hot Bodies pink tires in 4wd, but not in 2wd. Normally a AKA insert in the rear and standard insert in front. I use Sticky Kicks red for traction compound. Only Alex and Kyle have put down decent runs with slicks in the right conditions, nobody really runs them. Alex has been running Jconcepts Dirt Webs in black compound and says that they work well.
R/Cat,
Most racers prefer the tires to have 2 or 3 (6 min) runs on them before they feel like they are broken in and ready to run for their qualifiers and mains. Run the same tires for qualifiers and mains as long as they are not worn out and making the car loose.
stickboy007 wrote:IFMAR qualifying rules.
