Optima Mid Racer Build
- Been thanked: 325 times
Re: Optima Mid Racer Build
I'm just glad you didn't say you liked Jake's nylons.DennisM wrote:I´m not hating Jakes arms, heck I even like his legs![]()
- Been thanked: 10 times
and if you read agin you will see the text regarding the mids chubs and wideness.Seabass wrote:Sorry to bust your bubble but I am using LA219-7 outers with 73mm unis and the car is within IFMAR rules. A 4wd car maximum width is 250mm or 9.842 inches. The car I built with wheels (exact setup as Mike is building) measures at exactly 249mm. So I ask how is this car to wide to race???isobarik wrote:if you are using the c hubs from the mid on the lazer arms the 65.5 unis will be to short but then again it will also be to wide to race with.
65.5 unis and lazer arms and zx5 c-hubs la-219-7 there is now way jose they are to short i use them myself.
the 73 mm unis are for the zx-5 sp / sp2 since they have copied losis setup i think the axle itself should be to short for the zx-5 hubs la 219-4/7/9
mvh IsobarikYou sound just like the dude from Oople telling me the car isn't going to turn building it this way...good thing I listened to him, huh. I initially purchased 65.5 unis to find they did not reach the outdrives.
I just wounder how you cant get the 65.5 unis to work since back in -97 i used the w-5063 unis in front when i drove my Lazer suspension featuerd turbo optima mid special in the swedish nationals and i drove on 4wheels not just on 2.
i have also used mips prox cvds in the front.
so we just have to agree to disagree shall snap some photos .....
will take atleast 2.5 hours before another post swe and can in og hockey final....
mvh isobarik
- Seabass
- Business Member
- Been thanked: 12 times
It has everything to do with wheel offsets plain and simple. I machined these front arms longer than the factory arms to make up the difference on current ZX-5 wheel offsets. If I ran the same wheels you ran in 97...the car would be too wide to race.
I initially said these arms were the same but I had to go back to look at what I actually did. The front arms are longer, rear arms are the same. This should clear up everyone's beef on this topic.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Well Jake, looks great so far. As for the questioners read thru the post again. There is 2 different conversations going on here with different setups...old and new....
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
It´s Mike´s buildklavy69 wrote:Well Jake, looks great so far. As for the questioners read thru the post again. There is 2 different conversations going on here with different setups...old and new....
Gone fishing
- j0pp3
- Been thanked: 4 times
Jake makes awesome stuff! A while ago, I bought his white nylon optima mid arms and his lay shaft for using a B4 slipper.
Cheers
Joel
Joel
- klavy69
- Moderator
DennisM wrote:
It´s Mike´s build
- Seabass
- Business Member
Nice, glad to see some progress on this one. I am looking forward to seeing more.
Jake
Jake
- Has thanked: 660 times
- Been thanked: 878 times
Had a little RC time today so i got some more done on the mid. I need to order universals for this, and shocks and figure out my turn buckle lengths.
that's looking awesome Mike.
I really like the B4 slipper setup, that easy to do? Thinking I would add one to my Lazer project.
- 1324 Views
Last post by mikea96
- 3700 Views
Last post by alcyon
- 1080 Views
Last post by phoenix
- 20 Replies
- 5593 Views
Last post by DennisM
- 68 Replies
- 23191 Views
Last post by Garage Hack
- 1041 Views
Last post by magic
- 953 Views
Last post by murphy3428
- 4202 Views
Last post by alcyon
