Gomachv's 4wd RC10 project- finished!
minimini
Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
Been thanked: 11 times
Re: I'm not sure what to call it, and not sure why I'm doing
Post by minimini »
gomachv wrote:Hyperdrive would work but they are pretty big! I'm looking for a pulley closer to the size of a nickel. A big pulley creates problems with battery locations and belt lengths.
Mini, just so we are on the same page- that is a first gen 2.25 stealth in there :mrgreen: not b2/t2 etc.
thanks for your help Jeff...... :)
when most of the ingredients available..... I would start a thread about this "Stealth 4" project.....exciting !!..... 8)
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
Well I was thinking more the pinion pulleys instead of spurs.
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Been thanked: 3919 times
Gotcha, lol I wasn't thinking. Long day.
The ideal pulley has a 3/8 hole or room for one, that way I can run it either on the slipper hub or over the slipper spring. I think the pinion pulleys would be a bit small- and more importantly expensive!
minimini
Post by minimini »
I did think of pulleys with 3/8" hole......but seems that there are not many choices in the market...... :(
Yes it will probably have to be bored to 3/8, so a nice plain aluminum pulley will be fine
clm
Post by clm »
Pehaps a diff pulley from a factory belt drive car like a Schumacher?
Chris
I had the kickup plate off for some changes and decided to snap a couple pics, here you can see the suspension mounts are just stock mounts trimmed.
More pics to follow soon :mrgreen:
Quick and dirty mock up on a chassis
Just under 9" with narrow wheels/wide tires (all I had laying around) and these are the old wide offset
minimini
Post by minimini »
need to drill another set of holes on the nose plate ??
I won't post pics of what I had to do to that noseplate :shock: it wasn't pretty.
It's a truck plate, cut way down, flattened to about 10 degrees, and the sides cut back to clear the arms. It's ugly. It only serves to check fitment. An aluminum custom one will follow. It looks like its in the long wheelbase setting but it's because of how the holes needed to be drilled.
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Post by vintage AE »
I love your ambition, and it's making me with I came up with it first.
I wonder if I'm the only one thinking of taking on your lead?
There are a lot of ways to go about it, my techniques won't suit everyone! I'd love to see others spin on this general idea.
vintage AE
I have one of Rod's RC10s sitting in my basement, I wonder if he will forget about it :lol:
I was thinking about using Klein arms and as much WOIN parts as I could, or even some re-re parts. Oh, the possibilities 8)
The kyosho components require a short arm and narrowing up the bulkhead quite a bit, so one thing to look for would be a front donor that has less offset to it. I used kyosho because it's a terrific fit and era correct but I'm sure there are better geometries out there
minimini
Post by minimini »
possible to add the nose tubes ??
yes.... kyosho C-hubs fit very well ...... you can see in my project car.... :)
http://www.rc10talk.com/viewtopic.php?f=35&t=17732&hilit=project+rc10+legend&start=15
Users browsing this forum: No User AvatarYandex [Bot] and 12 guests
