early JRX2 clean up and race prep :)
- LosiXXkid
Re: early JRX2 clean up and race prep :)
Servo posts are much better than tape - velcro for a servo is a definite no-no! RPM make a pair of servo posts and cost next to nothing, part # 70062
- knixdad
- Been thanked: 4 times
Velcro twists. Servo tape twists less.LosiXXkid wrote:Servo posts are much better than tape - velcro for a servo is a definite no-no! RPM make a pair of servo posts and cost next to nothing, part # 70062
Screws don't twist at all
- Been thanked: 325 times
That's not necessarily true.knixdad wrote:Velcro twists. Servo tape twists less.LosiXXkid wrote:Servo posts are much better than tape - velcro for a servo is a definite no-no! RPM make a pair of servo posts and cost next to nothing, part # 70062
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Yes, this car was drilled with servo post holes by the previous owner...so I continued that with a pair of posts. No tape or velcro.zuki250 wrote:So the servo is solid mounted? Not with servo tape?
- JK Racing
Got a TBG jrx2 body & wing in today. Working on masking, planning on matching my ReC10 if I can pull it off
- JK Racing
masking coming along just fine....maybe sling some paint this coming weekend.
I'm liking that paint scheme idea...looking forward to your color choices.
- LosiXXkid
How do you do it? I mean successfully mask on the inside like that......JK Racing wrote:masking coming along just fine....maybe sling some paint this coming weekend.
Looking good by the way.
That's not the hard part, IMO...it's when you've sprayed the paint, removed the mask, and found paint-bleed in various nooks & crannies, and have to painstakingly remove it.LosiXXkid wrote:How do you do it? I mean successfully mask on the inside like that......
- Diamond Dave
- Has thanked: 699 times
- Been thanked: 130 times
- JK Racing
3m 1/8th vinyl tape and blue painters tape.
I will be mirroring my ReC10 paint, mostly. I wont do the JRX2 roof in black, here was when I was masking my Protech I:
and the colors that I will match (other than the black, like I said):
- JK Racing
as I have gotten older...much, much older, I have learned to take my time and do it slowly, pull and move to even them up as much as I can. I havent always had the patience to do it. I truly wish I was better at mixing the paint for the airbrush, I do still rush through the painting itself. Old habits die hardLosiXXkid wrote:How do you do it? I mean successfully mask on the inside like that......
- Diamond Dave
It was the blue painters tape I was wondering about. I have used the green stuff and it does not create a clean edge.
Thanks for that, I will look into the better tape. I am going to give liquid mask a shot soon as well.
Looks good so far.
Looks good so far.
- LosiXXkid
Ahh! Our old friend 'patience' seems to be the key.....something I've always lacked when it comes to painting body's with more than one or two colours...JK Racing wrote:as I have gotten older...much, much older, I have learned to take my time and do it slowly, pull and move to even them up as much as I can. I havent always had the patience to do it. I truly wish I was better at mixing the paint for the airbrush, I do still rush through the painting itself. Old habits die hardLosiXXkid wrote:How do you do it? I mean successfully mask on the inside like that......
- 24 Replies
- 2360 Views
Last post by sandkil
- 1244 Views
Last post by Kyoshojoe
- 3155 Views
Last post by juicedcoupe
- 110 Replies
- 23750 Views
Last post by JK Racing
- 21 Replies
- 3539 Views
- 1447 Views
Last post by Mad Racer
- 753 Views
Last post by 1300GT
- 873 Views
Last post by kenooze
Google [Bot] and 3 guests
