Inventory updates
Moderator: mytimac
mytimac
Business Member
Has thanked: 7 times
Been thanked: 56 times
Re: Inventory updates
Post by mytimac »
I just acquired the remaining inventory from ABC HOBBIES in La Crosse Wisconsin. They have decided to cease operations.
I had already worked out deals for most of the older inventory over the last few years. But I now have put up some harder to find parts on the store for RC10 DS and B2. At the same time I have added back in a bunch newer Associated parts. The new stuff has some pretty good prices.
Over the next few months I will be putting a lot of T4 B4 TC3 TC4 NTC3 MGT and RC10GT2 parts on eBay. Anything T3 B3 and older is going to be on the store for now. Some HPI Savage, OFNA, and other misc newer parts will be going on ebay and the store over the next few months.
Here is a list of new stuff added to the store. A bunch of newer stuff was also reactivated on the store and is not listed here.
Losi parts
A4031 Battery Box Receiver Cover XXXNT
A5154 2.5” Spring 2.9 Rate Orange
**A8008 XX Bodies back in stock
Associated parts
3213 Stub Axle
3918 Steel Diff Assembly
4145 4-40 x 5/16 SHC Screws
4471B Micro Shock Alum Blue
4473 Micro Shock Rebuild Kit
4522 12LC T-Bar .063
4526 T-Bar Spacers
5407 O RIngs Red Silicone
6260 Turnbuckles 1”
6262 Turnbuckles 1.65”
6429 Shock Assembly Tool
6436 Shock Body 1.02 Stroke
6459 Shock Shaft 1.02 Stroke
6471 Shock Rod Ends
6562 Fixed Gear Hub
6571 Drive Gear and Shaft
6581 3/32 Carbide Diff Balls
6587 Torque Control Spring Locknut
7253 Turnbuckle 2.620
7253 Turnbuckle 2.62” Fits T2 RC10T
7323 Rear Body Mounts
7337 T2 Servo Washers Steel
7357 Rear A Arm Hinge Pin
7373 T2 Motor Plate Gasket
7658 8-32 x 3/8 Alum FH Screw
8186 Rear 5” Body Mount
8232 Buggy Front Racing Spring Black
8324 .063 SS T-Bar
8405 Upper Suspension Arms
8411 Upper Suspension Arm Eyelet
8417 Pivot Ball
8423 Kingpins
8425 Kingpins
8443 Inline Axle for Dynamic Front
8812 Turnbuckle 0.75” Fr Rr Camber Rod
8828 DS Sport Roll Bar Cups
8830 DS Roll Bar Pivots Alum
8844 DS Shock Shaft
8864 Rear Outer Hinge Pin
8910 Exhaust Manifold Nitro DS
9115 Front Outer Hinge Pin
9162 1/8 x 1/4 bearing B2 Servo Saver
9175 Turnbuckle 2.25”
9256 B2 Rear A-Arms Carbon Fiber
9260 Rear Inner Hinge Pin
9263 Rear Outer Hinge Pin
9271 B2 B3 Rear Shock Strut Carbon
9275 B2 Universal Axle
9310 Front Shock Body .89 Stroke
9311 B2 B3 Front Shock Body .89”
9361 Idler Gear Shaft
8868 Rear Stub Axle
8869 Universal Dogbones DS
HPI R40 Parts
2117-070 SP Swing Shaft for R40
72275 Shaft 3x60mm
72276 Shaft 3x84mm
72277 Pin 2x12mm
72445 Diff Shaft 6x25mm
72447 Pivot Ball 7.9x18mm
73476 Rear Bulkhead Set
73477 Pulley Set 23T 22T 19T 18T
73478 Suspension Arm Rear Hub Set
73479 Suspension Mount Set A
73480 Bumper Set
73481 Diff Pulley Set 46T 36T
73483 Front Bulkhead Knuckle Set
73485 Spacer Set
73486 Bushing Set A
76971 Threaded Pinon Gear 21T
A726 Belt S3M 405 135T 5.0mm
A727 Belt S3M 189 63T 5.5mm
Z264 Pin 2x10mm
mytimac
Business Member
Post by mytimac »
Another update from the closed hobby store. This all the new stuff. There has also been some returning parts for Losi and Associated not listed.
Parts for Associated
RPM 80547 RC10T, T2 & GT Adjustable Width Body Mounts Yellow
RPM 7072 RC10T, T2 & GT Mini Front Bumpers Blue
7420 Front Shock Screw RC10T
7673 4-40 x 5/16 FH Screw
7773 6-32 x 3/8 BH Screw
6592 Allen Wrench set
7379 CVD Bone T2 T3 GT
9278 CVD Bone B2 B3
7380 CVD 3/16 Axle
9156 Servo Saver Hub Silver
9353 B3 T3 Diff Assembly
9340 B2 Rear Chassis Plate Black
9254 Rear Anti-Roll Bar Kit *See Note
7206 Truck Front Arms
9230 B2 Battery Hold Down
9650 RC10B4 Decal Sheet
3814 T3 Decal FL Yellow and FL Red
7340 T3 Rear Suspension Arms
7204 T3 Front Suspension Arms Carbon
7205 T3 Front Suspension Arms Comp
3821 B3 Decal FL Yellow and FL Red
9143 B3 Front Shock Strut Carbon
Tamiya
9495235 Sticker Bag BMW 318i STW
Losi
7321 RPM Losi Outdrives
a8038 XXXCR Body and Wing
A7156 A7056 Red Fr Rr Wheel Set XXXT XXXNT
mytimac
Business Member
Post by mytimac »
New things and returning things. Still working on some of the pictures.
Trinity
trishirt Trinity and Losi Revenge of Monster Shirt size XL
tk3080 XXCR Wide Front Axles
tk3044 Kinwald Associated Shock Bushings
tk0300 GTX LXT NXT Front Shock Tower
7025 Foam Bumper On-Road & Oval
Losi
a3033 XXXS G+ Sticker sheet
a2226 Rear Hub XXXS
a3247 One-Way Hub with Bearings XXXS/4
a9970 CVD Steel Driveshaft XXXS
a3097 Molded Outdrive Set w Rings
a9928 MIP CVD Set XXXS
a3238 Top Shaft w Hardware
a3098 Molded Diff Thrust Bearing
a9747 Graph Fr Spindles Carriers XXXS
a4216 Motor Mount Clamp
a3226 Lower Motor Plate
a1229 Low Roll Ctr Pivot Block
a4229 Body Mount Set XXXS
a4209 Gear Cover XXX4 XXXS
a9856 1 Deg Offset Rear Hub
a8115 Aurora Buggy Wing
a3282 Machined Idler Pulley
a4232 Foam Bumper Body Protector
a9671 Alum Fr Main Pivot 5Deg
Robinson
8575 75T Machined Spur Gear 48P (For Losi LRM Non-Slipper)
8581 81T Machined Spur Gear 48P (For Losi LRM Non-Slipper)
8593 93T Machined Spur Gear 48P (For Losi LRM Non-Slipper)
RPM
8125 Street Weapon Hex Adapters
HG
8210 Titanium Hinge Pin Set XXCR
MIP
1039 CVD Bones for LXT GTX NXT
MB2000 LXT Bones for LRM Transmission
Associated (mostly RC10GT)
9241 Rear Chassis Plate B2 T3
2219 19T Clutchbell RC10GT
7605 15T Clutchbell RC10GT
7968 20T Clutchbell RC10GT
7610 Standard Flywheel
7665 Drive Shaft Roll Pin RC10GT
7719 GT NTC3 Fuel Tank
7762 64T RC10GT Spur Gear
7562 Throttle Return Spring
7557 Throttle Pivot RC10GT
7651 Rear Suspension Mount
7652 3Deg Rear Suspension Mount
7602 Clutch Nut for Dynamite
7656 GT Rear Shock Strut Carbon
7618 Flywheel Collet RC10GT
7561 Disc Brake Adaptor Alum
7601 Clutch Shoes RC10GT
2213 Hardened Steel Idler Gear
7197 RC10GT Decal Sheet
mytimac
Business Member
Post by mytimac »
Been a while since I posted in here. Just been too busy to post much. But another store wanted to move out old stock so a lot of stuff came in all at once.
I have not kept track of all the stuff that returned to stock. All week I have been adding it back into the store and bunch has already gone back out the door.
But I do have a list of new items. You can also just go to the new products page as well.
http://sabulatech.com/storefront/new-products.php
Associated
9105 Front A-Arms Black Composite B2
9255 Rear A-Arms Black Composite B2
9454 Wing Wire .065 Pre Bent B2 B3
6693 81T Spur Gear 48p
HPI Stuff for RS4, Pro, Pro2, Pro3, MT, Rally, Mini, Micro and MT. Also one F1 part.
A362 Suspension Mount Set Pro2
A350 Upper Suspension Mount Set
A218 Rear Shock Mount (Woven Graphite)
A236 Pro Graphite upper deck RS4
A248 Heat Sink Motor Mount Plate
A289 Heat Sink Motor Plate
A788 Motor Plate (Purple Anodized)
A400 RS4 Super Handling Set
A452 Suspension Arm Set Pro2
A491 Pulley Set 36T 16T
A514 Universal Dogbones Rear Wide
A517 Mini Universal Dogbones Rear
A518 Universal Dogbones (front) RS4 MT
A550 Dog Bones 6x42.5mm Silver
A570 Front Shock Tower (graphite)
A705 Rear Shock Tower (graphite)
7111 Gear Cover RS4 MT
A043 F1 Wing Set with Screws
73465 Wheel Set Type 2 Gold
Traxxas
1625 Front Bumper Black
1886 Dust Cover and Gasket
1997 Mounts Suspension Arm
Losi
A7802 5 Spoke Sedan Wheels Yellow
A7077 Truck Disc Front Wheels Yellow
A9708 XXT Kingpin Ball Set
A3151 Cross Bone Driveshaft AD2
A3157 Cross Bone Axle AD2
A3023 Offset Rear Axle Spacer Set
A5358 10mm Springs .75 x 70
A5357 10mm Springs .75 x 60
A5356 10mm Springs .75 x 50
A5355 10mm Springs .75 x 42.5
A5352 10mm Springs .75 x 25
A4119 Bumper Guard Body Mnts Yellow
A5321 10MM Shock Plastic Set
A4233 Xtra Resilient Foam Bumper
A4019 Alum Chassis XXXNT
A4105 XXX Main Chassis and Brace
A4202 Main Chassis XXX4 (sold)
A3104 Threaded Rear Axle Adapt
A9760 Fr Spindles Carriers 0 Deg
A4027 Transmission Brace XXXNT
A9677 Alum Rr Main Pivot 1 Deg
A6029 Ball Studs Ends Short Neck
A9847 Graph Rear Hubs
A6233 4-40 x 5/8 FH Screws
A3266 Slipper Hub Plate Flange
A6245 4-40 x 5/16 BH Screws
A5049 Alum Shock Adjustment Nuts
A2933 Diff Screw Hardware GenII
A1547 Steering Servo Saver Mounts
A4250 Sway Bar Set XXXS
A1117 Front Arms VLA EA3 XXXT
A9967 MIP Alum CVD Set Front XXX4
A9922 CVD Set XXT XXXT XXXNT
A3972 90T 48P Kevlar Spur
A3970 128T 64P Kevlar Spur
A5043 Teflon Shock Pistons 60
a5056 1.2” Threaded Shock Bodies (black nut)
a5055 .9 Threaded Shock Body Set (black nut)
a5054 .6 Threaded Shock Body Set (black nut)
A3965 92T 48P Kevlar Spur Slpr XXX4
A3966 94T 48P Kevlar Spur Slpr XXX4
mytimac
Business Member
Post by mytimac »
Be sure to check out yesterdays big update if you haven't already.
Today some more stuff came back in for Losi people and some HPI tires will be going up soon. Both listed farther down.
Also if you missed the 3D printed parts update, there are some new parts announced so check them out. Losi stuff only.
http://www.rc10talk.com/viewtopic.php?f=92&t=34886
Losi stuff up already.
A9831 Graphite Rear Plate XXX XXXT
A9833 Graphite Rear Plate XXX BK2
A4122 Front Kickplate XXX
A2108 Rear Plate EA3 XXX
HPI Tires coming soon
4495 Belted X Pattern 26mm
4597 Slick Tire Belted 2.2in 27R
4592 Slick Tire Belted 2.2in c10-30
4596 Slick Tire Belted 2.2in 23R
4763 Advan Belted Tire 24mm 33R
mytimac
Business Member
Post by mytimac »
Just got in a bunch of stuff back in and new items.
Few things got added Monday and already sold to people who had email alerts setup.
Here is a list of things never before on the store. Still working on photos.
Stuff for Associated
4337 Aluminum Tube
4359 Diff Spacer
4551 Graphite Axle for 12L3
Stuff for HPI RS4 and F1 models
6276 Foam Bumper RS4 Mini
7092 Long Titanium Shock Mounts
8402 10L2 Front End Brace
a001 F1 Front Suspension Set
a002 Steering Parts set F1
A160 Diff Hub
a171 Dog Bones 6x33mm
a175 Drive Axle5x32mm Front
a190 Gear shaft and set screw
a191 2 Speed gear shaft RS4
a216 Wide Nerf Wing Graph
a232 Pro Graphite chassis for RS4
A259 Side Plate
a297 2 Speed Transmission RS4 Pro
a330 Suspension arm set
a352 Suspension Mount Set
a490 32T Pulley Set (gear diff)
a497 Graphite Diff Hubs
a510 Universal Dogbones Narrow
a513 Universal Dogbones Front Wide
a575 RS4 Mini Main Chassis
a585 Mini Upper Deck
Stuff for Losi Models
870B Losi XX Motor Centering Kit (factory works)
a0911 XXXNT AD2 ROAR TQ Chassis Kit
a7154 R Truck Wh Natural XXXT XXXNT
a9952 Blue Alum Ft Axles XXX
tk5019 XXX Rear Sway Bar Mounts (trinity)
1105 XX4 Set of Fr Rr Alum Shafts (HG)
2515 Alum Blue Front Brace XX XXT
mytimac
Business Member
Post by mytimac »
The new stuff is listed in post before this. Here is a list of some of the returning parts.
Losi
a2002 jrxt jrx2 rear pivot
a9750 graphite front arms lxt gtx nxt
a1131 XX Front Stub Axles
a2012 Assembly Wrench
a3048 Gear Cover With Plug XXXT
a1009 Camber Link Tie Rod 1.5" (old style)
a1011 Long Tie Rod Set (old style)
a3008 Diff Adjust Cover
a7128 2.2" Disk Wheel Caps
a7039 XX Front Wheel Discs
a9924 Buggy Alum Dog Bones
a4110 Chassis Brace Set XX XXT
a4056 XXT Front Body Mount
a3078 Diff Screw
a3013 Molded Universal Set
a8102 Adj Wing Button Set
a9850 Graph Rear Susp Arms GTX NXT LXT
a9730 XX4 Street Weapon 0 Deg Fr Bulkhead
a3218 O-Ring for Outdrive Bearings XX4
a2107 CR Rear Pivot Plate
a9960 GXT NXT Graph Center Chassis Brace
Associated
7354 Truck Rear Arms RC10T T2 GT
9130 B2 Front Plate Black Comp
7556 RC10GT Brake Cam Clip
7258 Servo Saver Tube
6469 O ring shock gaskets
8870 DS Rear Shock Strut
7217 Shock Rod End
7657 RC10GT Rear Shock Mounts
9165 B2 Steering Bellcrank
Peak / Team Homies
PEK6020 Rear Trans Brace XX XXT
RPM
7379 One Piece Centerlink Bellcrank XX XXT
HPI
A218 Rear Shock Mount (woven graphite)
A370 Upper Suspension Set
mytimac
Business Member
Post by mytimac »
Huge update of lots of stuff. Lots of things have come and gone over the last month. But I have been so busy I just didn't have time to do an official update.
Here is the last two lists of new things never before on the store that have been added. Some have already gone on to new homes. Some pictures done but lots to do still.
Stuff for Associated models
2250 Super Star Rear Wheel RC10 White
2255 Super Star Rear Wheel RC10 Black
2095 T2 Front Oval Shock tower (Factory Works) **I have always thought this shock tower is awesome)
4338 Tube Collar Lower
3423 Wing Tube Brace
HPI Models
A189 Turnbuckle M4x18mm
A007 King Pin 29.5mm
A784 (A183) Pilot Shaft 4x15mm
A50347 Clutch Shoe Plate Proceed
50537 Front Stabilizer Bar Set
a252 Gearbox Plate (Graphite)
50536 Front Sway Mount Set
A453 Suspension Arm Set
A067 Axle Spacer 5mm
73081 Steering Plate (graphite)
2103 Alloy Front Shock Tower (HG)
tk5003 RS4 Pro 2 Belt Guide (Trinity)
Traxxas Models
1714 WIng Buttons Wing Wire
1631 Front Arms Bullet
1652 Stub Axle Housing
1653 Stub Axles
2630 Suspension Arm Bracket
3219 Starter Cover White
3312 Rollcage Hardware
1229 Front Shocks
1880 Motor Plates Aluminum
4704 Shock Tower Graphite
Tamiya Models
8516 Rear Jumbo Dawg Rims Blackfoot Beetle Blaster (Imex)
1513 Chrome Body Brackets-Servo Mnt-Horns Clod Buster (Chrome Works)
4587 Fox Universal (Thorp)
1556 Front Shock Kit Hornet (CRP)
YA0067 Front Bumper Quick Drive Trucks
X9801 A Parts Tree 0005231
y2815 Steering Rods 9405131
43001 Front Tire With Wheel
9005484 H Parts
x10232 9405468 Damper Bag
0005713 A Parts
50456 Benz 190E AMG Wheel Set
Kyosho Models
LA-26 Lazer ZXR Suspension Arms
LA-20 Suspension Shaft Set SOLD
LA-27 Front Hub Carrier
LA-32 Front Axle Box
XR13 Suspension Shaft Set
XR1 Front Suspension Arms
UM-73 Bumper Set
UM-54 Screw Set Ultima Pro SOLD
BB19 Front Guard Set Hi-Rider
MA-8 Main Chassis Maxxum FF
MI-14 Suspension Arm Pin
MI-15 Thread Set
XR-09 Body Mount Set
92331 Ball End 4.5mm
MIW4 Steel Drive Gear
MI2B Body Mount Set
xr63 Small Parts
FD13 Slider Set
FD70 Brake Disc Rotor
SM61 Rear Extension Stay
SM38 Shock Set Long
FI-77 Parts Set for Spare Body
RM-16 Body Parts Set
DA6 DA-06 F Block Parts
1921 Motor Case
Front Parts Set Bag
39631 BODY PARTS SET BAJA BEETLE
OR-6 Pulley Set
LAW-06 B Shock Tower Fr
OT18 Rear Wheel Shaft
RM2 Plastic Parts Set
SM4 Front Bulkhead
XR11H Rear Shock Stay
XR4Z Front Hub -5 Degree
92308 Engine Mount
BS53 Shim Set
XR60 Rear Shock Stay
TM26 Shock Stay Rear
LA10 Belt Roller Set
MI19B Small Parts for EP
MI18B Frame for EP
MI33 Bulk Head
XR3B Front Bulkhead
OR28 Body Mount Set Chevy Truck
OR8 Center Axle Mount Set
FD43 Servo Saver Set
LA23 Servo Saver Shaft Set
SP68 Center Mount Set
XR21 Rear Bulkhead
39534-2 Mclaren F1 GTR Parts
39762-2 Wild Dodge Ram Body Parts
w5667 Adjust Rod Long
SPW05 Front A-arm Set
FJ35 Front Wing F1 (target)
FJ16 Front Wing (williams) F1
FF22 Wheel Set
GP7 Cowling Set Honda NSR 500
KY100 Competition Out Drives Ultima Optima Mid (MIP)
Kyosho HPI Chrome Offroad Wheel Set SOLD
Futaba FX10 / Tamiya Striker
fx10-006 B Parts Front Shock Tower and parts
fx10-008 D Parts Suspension Arms
Losi Models
2560 Rear Cone Dish JRX2 SOLD
2578 Rear Wheels JRX2 2.15 Diameter SOLD
2571 JRXT JRX2 Truck Rear Wheel
mytimac
Business Member
Post by mytimac »
Here is a small list of things that came back in stock recently. Not all things.
Associated
6190 Wing Mounts White
4350 Axle Bearing Height adjust White
8205 (kid you not, just sold as typing this)
7250 servo saver Black
Losi
a2125 rear hubs
a1131 Axles
a2209 rear brace xx4
a9753 4 deg spindle set XXXS
a2038 Rear Hubs
a2017 Rear Pivot support
a9840 XX4 rear tower
a5020 Shock Set Grey
a2112 rear pivot block
a1508 Rigid Steering Bearing
a2113 rear pivot block
Traxxas
4707 Shock tower
2750 Rear Arms
4703 Shock tower
2521 Top plate
HPI
a168 Servo Saver Shaft
a218 Rear Shock mount
a247 Motor Plate
6085 Alum Wing Buttons
mytimac
Business Member
Post by mytimac »
Some returning parts that just came in. Some new parts will be added some time on Monday probably. Only about 6 things.
Losi
A1108 XXt Front Tower
A1610 Steering Set
A3980 Kevlar 76T Spur
A9310 Fuel Tank
A9822 XXXT Rear Tower
A8102 Wing Buttons
A3930 Spur Gear 84T
Associated
7318 Fr Body Mount
7355 T2 Rear Strut
mytimac
Business Member
Post by mytimac »
New to the store today.
Losi
A3993 90T Kevlar Spur
(back in stock today a9913 XX4 cover with grey "graphite")
CRC
4050 Motor Heatsink Losi XX (purple)
Proline
2612Y Eliminator Front Truck Wheel XXT Yellow
HPI
2190 MEsh Wheel Front White RC10T XXT
2191 Mesh Wheel Front Black RC10T XXT
3060 Split 5 truck Wheel White RS4 MT /Nitro (with universal adapters for other models)
6788 Spring 13x57x1.1mm
6794 Spring 13x70x1.1mm
6796 Spring 13x70x1.1mm
6816 Silicone O-Ring S10
6819 Silicone O-Ring P-3
72001 Pilot Shaft 4x30mm
72100 Shock Cap 12x0.8mm
72144 Linkage Set Nitro RS4 MT
72148 Brake Cam Shaft Plate Set
72150 Exhaust Manifold RS4 MT
72157 Arm Brace Set
72171 Stainless Steel Hinge Pin Set
76814 Spur Gear 44 Tooth
76822 Spur Gear 52 Tooth
A243 Belt 58T
A244 Belt 188T
A280 Flange Shafts
A346 Suspension Mount Tower Set
A347 Gear Box Set
A431 Diff Case Nitro RS4 MT
A435 Gear Diff Pulley Set MT
A442 Spur Gear 37 Tooth
A449 Spur Gear 44 Tooth
A456 Suspension Arm Set
A470 Rear Bulkhead Set
A473 Shock Parts Upper Arm Set
A518 Universal Dogbones Front
A558 Differential Shaft
A559 Gear Shaft 5x37mm
A812 Clutch Bell 12 Tooth
A813 Clutch Bell 13 Tooth
A827 Clutch Spring 0.7mm
A832 Center Gear Shaft 5x55mm
A855 Diff Final Gear 38T 13T
A885 Nitro Racing Clutch MT
B021 Ball Bearing 5x10x4mm
B072 Metal Bushing 5x11x4mm
Z136 Ball End 4-40
Z242 E Clip 2mm
Z282 Step Screw M3x14mm
Z526 Flat Head Screw M3x8mm
Z543 Cap Head Screw M3x10mm
Z569 TP Binder Head M3x15
Z581 TP Flat Head Screw M3x18mm
Z593 Screw Shaft 3x27mm
Z684 Flanged Lock Nut M4
Z695 Washer 4x6x0.3mm
Z710 Set Screw M3x22mm
Z892 Washer 10x12x.2mm
Z960 Turnbuckle Wrench
mytimac
Business Member
Post by mytimac »
Some Losi stuff only in.
New Things to store
Trinty
TK1100 XX4 HEatsink
Losi
A2943 XXX GenII Gear Cover
A3935 XXX GenII Outdrive Set
A5301 10mm JRXS Shock Set
A4104 Main Chassis XXXCR
A9734 XXX4 GRaphite Fr Arms
Returning Parts
A1112 XXXCR Fr Arms
A1507 Rigid Arm Black
A3991 88T Kevlar Spur
mytimac
Business Member
Post by mytimac »
A few new and returning parts
Associated
8211 RH Rear Wheel Diff Spacer
RC Performance
915 RC10 B2 Titanium Combo Kit
HPI
A463 Carbon Graphite Rear Bulkhead Set
A491 Pulley Set Pro3
Losi
A3072 Diff Tube
A4122 Fr Kickplate Bulkhead
A7030 XX Front Wheels White
A7105 Rear Wheel White XXX XX XX4
A7104 Rear Wheel Yellow XXX XX XX4
A7077 Truck Disc Fr Wheels Yellow XXT
A9896 Graphite Fr Rr Diff Covers
A9911 Graph Long Battery Strap XXXT
A9833 Graphite Rear Pivot Plate BK2
A2113 R Pivot 2 Deg CR
A8101 Wing Wire
A3057 Retrofit Trans Screw Set
A9671 Alum Fr Pivot 5deg
A9673 Alum Fr Pivot 10deg
A2005 Rear Camber Link w/ends
mytimac
Business Member
Post by mytimac »
Big update was just done.
Here is some of the stuff back in stock. I will have a list of new stuff never in stock before later. There is big list.
Losi
A2009
A2113
A3097
A3036
A3124
A3993
A4030
A4104
A4160
A4229
A5015
A5022
A5079
A6401
A9713 (sold)
A9928
A9955
A9968
A7065
A7155
A7154
A7104
A7105
Trinity
TK5061 XXXNT Brake Hub
Duratrax
DTXC6845 Evader XX Front Bumper in Black
Team Associated
6610
6611
6612
6620
6621
6623
6624
mytimac
Business Member
Post by mytimac »
Here is all the new stuff that was added for the first time. Lots of various old Kyosho Parts. Also some good Tamiya parts.
You can also just go to new products section to see pictures as well.
Trinity
7044 Sway Bar For Blackfoot
Traxxas
3270 Assembled Starter
1814 Body Posts - Hinge Springs
1782 Planetary Gears
Team Academy
EXT-3 Wheel Hub SP3
Tamiya
X9414 A Bag Parts
9805229 Drive Shaft
9805099 Cylinder Cap
9495252 Sticker Williams Renault
9405873 B Parts Bag
9405668 Pressure Plate
50625 TGX Drive Shaft
50554 Touring Car Rear Uprights
50509 F-1 Front Spring Set
1825540 Body F1
Sabula Tech
BL2394-B Funco 2 Seater RC10 Body
J201 Jammin RC10 Repro Body
RPM
8092 T2 Zero Deg Rear Toe-in Blocks
Parma
12829 Heavy Duty Fox Tie Rod Kit
MRC
9432044 Body Mount Set Hammerhead
MIP
3081 360 Stinger Kit for XXXNT
3002 360 Stinger Kit for RC10GT
Losi
A9870 R Hub Carrier 1 Deg Offset EA3
a9815 Graph Rear Arms AD2
A9705 25 Deg Carrier Machined
A5135 2” Spring 4.1 Rate Black
A4151 Fan Mount XXX XXXT CR
A3325 Diff Pulley Set 41 42 JRXR
a3089 Driveshaft XXX Gen II
Kyosho
xr5h Knuckle Arm
XR29H Rear Susp Arm Truck
XR28H Front Suspension Arm Set
XR22H Rear Hub
XR16 Steering Arm
WBD-4 Pressure Plate
W5141 Sport Shock Set
W5099 Ultimate Shock L
W5098 Ultimate Shock M
W-5080 Equalizer Shocks (short)
UM-9 Rod Set
UM13 Susp Arm Set
TMW-2 Front Hub -10 Deg
TMW-1 Front Hub -5 Deg
TM-2 Front Hud Set
SST7H Drive Shaft
SST5 Differential Gears
SST38 Brake Cam
SST37 Diff Plate
sm28 Gear Set
SG-2 Gear Set
RV41 Belt (for EP)
RS13 Servo Saver
RM-23 Protector Plate Set
RD-6 B Shaft Set
PI4 D Z Block Parts
OT5 Joint
OT5 Rear Hub
OT45 Rear Hub
OT4 King Pin
OR111 EG Body Attachment
MT001 Suspension Arm Set
LD70 Clutch Bearing
LA-28 Rear Hub Carrier
KC7 King Pin
FJW8 Ball Diff Set
fd7 Timing Pulley
FD4 Center Diff Case
FD4 Final Differential Case
FD3 Belt
FD-21 Fly Wheel Set
FD17 Servo Mount Set
DA8 A Block Parts
DA27 Susp Arm Set
DA26 Wheel Shaft
BV4 Shock Stay
BS57 Front Hub Carrier
BS55 Wheel Stopper Bolt
bs110 Shock Stay
AB-28 Gear
AB17 Clutch Spring
AB14 Pilot Shaft for OS
96314 Pilot Shaft For OS GT
92631-05 Shifter Idler Shaft
6510-10 Head Gasket
39307 Cooling Fan Set
39306 Special Disk Brake Rotor
1857 Spark Generator F1
JG
tgh-01 Heavy Duty Steering Kit
KO-06 Optima Dual Rear Shock Mount
5006 Blackfoot Steering Kit
HG
hg1100 Titanium Top Shaft GTX NXT
Dirt Burners
5309 Cheater Gear Set
Dans RC
10049 Tamiya F1 Motor Plate
CRP
4114 Wheel Adaptor Hotshot to Kyosho
1604 Heavy Duty Steering Grasshopper Hornet
1603 Heavy Duty Steering Frog Brat
Team Associated
8202 Lower Brace Aluminum
7771 GT RTR Pull Start Motor Mount
4402 12L4 Front Suspension
A&L
2080 Ultima Steering Bellcranks
Return to “Announcements”
