Project Circle Track
Re: Project Circle Track
Buy a lipo sack...The biggest danger with them lipos is fire...I am new to the lipo thing and am reading everything i can about them...Good luck at the racetrack and remember to keep the rubber side down...
Two Devil's Bowl bodies arrived today from McAllister. I managed to trim and mask one body in between turkey sandwiches. I thought I had a half can of black but realized I have a half can of silver.Russ Winn wrote:Thanks a lot...I'm going to the track tomorrow to try and get it dialed in.
You been working on your build lately?
I picked up a used $25 3300kv Reedy brushless motor which I believe is the equivalent of a 13.5 turn. Lipos and a can of black paint are next. I'll pick up the paint tomorrow and update the bomber thread.
Not a bad looking car Russ ty for sharing here.
You run me in the grass imma run you in the wall, drive like a racer not a flippin idiot
THIS PLACE ROCKS!!!!
- Russ Winn
- Has thanked: 49 times
- Been thanked: 80 times
Thanks Bent. I'm finally having fun with it again. Keep us posted on how it's going at the track.
I debated that body myself, but wasn't sure how it would fit the around the front tower...I'll be checking the bomber thread for the progress. Hope to see you at the track soon.knucklebuster wrote: Two Devil's Bowl bodies arrived today from McAllister... I'll pick up the paint tomorrow and update the bomber thread.
I modified the modified body. Hacked off the front fenders. I hoped the narrow nose would fit between the shock tower but it does not. IMO it looks pretty cool, appropriate for the bomber class.
How did you fair at the track yesterday? Did you get dialed in?
What knucklebuster said...How did you do ?????
- Russ Winn
I found the gearing needed, and got it to turn in really good. It still pushes coming off the corner under power, but I'm almost there...It's a different technique than what I'm used to, so I have to train myself NOT to pitch it when I get to the corner. Also, I spoke to Butch (track owner), and the next race is Dec. 1 ....I plan on being there, for better or worse.
- THEYTOOKMYTHUMB
- Has thanked: 3709 times
- Been thanked: 1980 times
If you get a chance grab a little video. I'd love to see that thing flying around the track Lightning McQueen style!
Russ, did you go with a larger pinion? I recall your original setup was based on brushed gearing (81/18~20). I was shocked to hear folks are running 30+ pinions with brushless setups. That is larger than I run in the pan cars!
Rem, I use a Dremel to cut bodies.
- THEYTOOKMYTHUMB
I visited my cousins and life long friends a couple of weeks ago and about died laughing at the 1/1 gear ratio of their single cell 12th scales.knucklebuster wrote:I was shocked to hear folks are running 30+ pinions with brushless setups.
- Russ Winn
My original gearing was 23/81, but I had to go DOWN to a 20 on the pinion. I suppose that might change after I cycle my batteries a few times. They should get better, if I'm not mistaken. It was kind of strange mixing and matching springs and shock oils, but due to track conditions and modern tires, the old way of thinking doesn't apply much...but it's cool watching it pull the left front coming off the corner.knucklebuster wrote:Russ, did you go with a larger pinion? I recall your original setup was based on brushed gearing (81/18~20). I was shocked to hear folks are running 30+ pinions with brushless setups. That is larger than I run in the pan cars!
Rem - I use a dremel, as well...worth it's weight in gold.
- Russ Winn
How long were the straights?...I bet they crawled around a tight track.THEYTOOKMYTHUMB wrote: the 1/1 gear ratio of their single cell 12th scales.
- THEYTOOKMYTHUMB
Road course. They run close to touring car speeds, but a little more stable even with just the 2wd. Made for good racing.Russ Winn wrote:How long were the straights?...I bet they crawled around a tight track.THEYTOOKMYTHUMB wrote: the 1/1 gear ratio of their single cell 12th scales.
The key with 1/12 pan car racing is to try to keep your speed up. Once to motor is "on the pipe" so to speak those things REALLY move. The WHOLE body is designed for maximum downforce. It's crazy how well they get around the track on a 1s pack!
- Russ Winn
I've seen them run before, with brushed motors and 4cell Nicd...some of those guys are really good. I'm sure 1S would be plenty for something that light...but with gears close to 1/1 ratio, I figure you'd have to push it off to get it started.
- 3016 Views
Last post by Russ Winn
- 919 Views
Last post by PBR Allstar
- 534 Views
Last post by Halgar
- 509 Views
Last post by LowClassCC
- 2421 Views
Last post by TycoTamiya4eva
- 932 Views
Last post by Fred19K
- 53 Replies
- 10661 Views
Last post by Jeep-Power
- 2646 Views
Last post by naushad
