Pink RPM Truggy
Asso_man!
Has thanked: 40 times
Been thanked: 81 times
Re: Pink RPM Truggy
Post by Asso_man! »
Ed, inner rear hinge pins are 5,3 cm, just use the stock ones for the outer ones :wink:
By the way, which rear bulkhead do you plan to use?
Cheers,
David
Come and visit the stable
Dr. Robotnik
Re: Pink RPM Truggy
Post by Dr. Robotnik »
Asso_man! wrote:Ed, inner rear hinge pins are 5,3 cm, just use the stock ones for the outer ones :wink:
Cheers,
David
Wow David, that was amazingly quick thanks, 5.3cm got it! I have an RPM Truck rear bulkhead on the rear as I'd like to do a super low profile body (I wonder where I'll get one :wink: ) on this car. I got the idea from that German guy whose name escapes me who had a cut down chassis and truck rear tower on his RC10 giving a real mean look.
Do you think the truck bulkhead is the problem?
Cheers
Ed
Dr. Robotnik
Re: Pink RPM Truggy
It is siebenelch's car's low profile I am trying to imitate with a super low profile body!
It's in this thread and is pretty badass to say the least 8)
http://www.rc10talk.com/viewtopic.php?f=4&t=1726
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: Pink RPM Truggy
Post by Mr. ED »
Cool aspirations ED, but I hope you'll take it further than a copy.
Now if you 'd use short and medium sized shocks with custom shock plates: so the shocks could stay under the roof in the rear. Mount them on the inner hole of the arms, with thick oil and stiff springs for to sustain damping and travel
Maybe lay down the shocks in the front...
(Better watch myself; don't want to start another build before the workspace is cleaned up)
Dr. Robotnik
Re: Pink RPM Truggy
Mr. ED wrote:Cool aspirations ED, but I hope you'll take it further than a copy.
Hahaha, I hope my buggy won't be a copy at all. I am using different suspension arms front and rear and am just following the use of the truck rear body mount for a lower body stance.
I had hoped to do something special with this car but you will all have to wait and see what that is because this car is taking a lot of time just to complete the basic mods...
asashaw
Re: Pink RPM Truggy
Post by asashaw »
just use truck (rc10t) rear hingepins instead of going through all the trouble...
Has thanked: 33 times
Been thanked: 1185 times
Re: Pink RPM Truggy
asashaw wrote:just use truck (rc10t) rear hingepins instead of going through all the trouble...
yup, what asa said. :wink:
Dr. Robotnik
Re: Pink RPM Truggy
Thanks Asa and scr8p. I just need to find some RC10T hinge pins now. Pretty gutted really as I just put a massive order in at Tower through Mrlexan and this could easily have been purchased from there! :roll:
BTW Asso_man! I measured the arms this morning and they are 60mm wide so I guess you meant 63mm for the hinge pins right?
Dr. Robotnik
Re: Pink RPM Truggy
I guess you should never measure things before breakfast I have realised Asso_man! must be right and have modified some junk hinge pins accordingly on my lunch break to the 53mm he specified! Sorry for doubting you mate :oops:
The hinge pins I had were all mushroomed at one end and no good for a regular RC10 but by chopping the mushroomed end off I could shorten them for this application. Though not perfect this will allow me to mock up the rear end and get the rear bulkhead to fit tonight hopefully!
Asso_man!
Re: Pink RPM Truggy
Post by Asso_man! »
:lol: :wink:
Dr. Robotnik
Re: Pink RPM Truggy
So last night I got properly stuck into the build of this buggy. After work I purchased some more dye and came home for another dying session.
The first thing I did was install the modified hinge pins I'd made so I could modify the RPM truck rear bulkhead to fit with the narrowed rear chassis. This required dremelling into the back of the battery cup to allow clearance for the rear arms and to allow for full suspension travel. Once this was done and I was happy with the fitment, it needed re-dying as the cut away nylon was white.
I also dyed the front servo saver posts I made and re-dyed a graphite truck rear tower which was whitened by some scuffing.
This allowed me to assemble most of the rear end. I then got completely carried away and threw on pretty much everything I have to mock up how the truck will look. I won't write a spec as it's all subject to change but the pics (when photobucket comes back from maintenance) are pretty awesome if I do say so myself!
Dr. Robotnik
Re: Pink RPM Truggy
So photobucket has finished its maintenance and is back up allowing me to show off what I have managed to do so far.
I am really pleased because this car is made up of other peoples scrap parts and pretty much each piece has been, polished, sanded, cleaned, re-dyed, dremmeled or modified/fixed in some way. :D If this was cub scouts I'd definately get my Dremmel profficiency badge!
Have a great weekend y'all!
templeofspeed
Been thanked: 32 times
Re: Pink RPM Truggy
Post by templeofspeed »
Nicely done Ed.
Not every "restoration" need a pile of NIB parts. :wink:
I love the "casually tossed in" electrics too. :lol:
Dr. Robotnik
Re: Pink RPM Truggy
So I got some rear shocks and a body from Asso_man and some HPI wheels from Didou.
The project is really coming along now, I just need to cut the body to fit the RPM front shock tower and also drill the rear wing...
I am also waiting for the tranny and so it can't be let rip just yet!
I am super stoked on the massive mix of clashing colours!
templeofspeed
Re: Pink RPM Truggy
How nineties... :lol: Actually the pink and green complement each other. 8) Siebenelching the body?
Return to “RC10 Truck Forum”
Users browsing this forum: No registered users and 18 guests
