Blue pan
Been thanked: 498 times
Re: YOUR OPINION NEEDED!!!!!!!
it's cool man....not calling you out on where you got it, just sayin' i'm pretty sure I saw that picture on ebay, maybe the guy was selling another one of the cars?, i can't be sure because it was a week or so ago.
should clean up nicely with a little TLC!
Bent
Post by Bent »
Jwscab I know you ain't man. I've tore the front end off and it cleaned up pretty well I need some tires and new rods and had to replace a axle carrier. Other than that I think If I get the cleaner wax after it the tub will shine up nicely. I think. Any how will have pictures up tomorrow night the trans is soaking in peroxide now.
You run me in the grass imma run you in the wall, drive like a racer not a flippin idiot
THIS PLACE ROCKS!!!!
Bent
Post by Bent »
All clean
I Plan to dye some of the lighter parts and odd colored parts as well. I also plan to replace the electronics and have get a wing and body on it. Here it is for now.
rc10johnny
Post by rc10johnny »
Looks Good "B" :mrgreen:
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
Thats an early lite gold motorplate.Somebodys gonna want that lol DON
Bent
Post by Bent »
TY Johnny
Don, All they have to do is offer up, they ought to know that by now.
Ok Ive been reading the board for a week now and have found many many different ways to make the old white parts white again. I read that hydrogen peroxide works great. I figured at 2.00 a bottle it is worth it. I scrubbed the parts thoroughly, with soap and hot water. I then sat the parts in a bowl and poured the peroxide in and let sit in the sun for 4 hours. I just checked on them after bringing them in at 9pm and they are no whiter then after I washed them. I have bleach do I need to soak them in that? How long do they need to sit in each? What else can I do to make them whiter. I will let then soak in the peroxide for another hour then I will pill and towel off.
Has thanked: 33 times
Been thanked: 1188 times
you should've spent $2.00 on black dye and made the few white parts that are actually on it match the rest of the car.
my 2 pennies........
Bent
Post by Bent »
Sr8pe, I plan to rit dye parts but i do have more than one of these old cars and they have the white parts on them, I didnt want to start another "Dying parts" thread just to ask one lil question that's why I posted here
upforit365
Post by upforit365 »
I reckon you should dye all the nylon parts black (that aren't already), get a set of black wheels for the front and it's perfect!
Bent
Re: Blue pan
Post by Bent »
Ok never mind on the white stuff that I want to make whiter.
As soon as friday gets here I plan to go and get me some rit dye from walmart I will let you guys know how it turns out.
Bent
Re: Blue pan
Post by Bent »
I have a new spur gear and a old 6 gear trans. I do NOT know how the spur gear mounts so that it is tight enough to turn the wheels.
If any one could help Id really appreciate it. I will NOT toss the 6 gear for a stealth I want to have one 6 gear car in my collection.
JK Racing
Has thanked: 129 times
Been thanked: 242 times
Re: Blue pan
Post by JK Racing »
Bent, assuming the new spur gear you have holds the 1/8" diff balls (edited, sorry for the confusion), the gear will "float" slightly when tightened on the 6 gear, that is the external diff (not a slipper). Tighten it up, hold the spur and spin the rear wheels, they should move opposite each other. If it is very tight, slightly loosen the nut and retest until you are happy with the feel. Then place the car on the ground (or hold both rear tires) and attempt to rotate the spur by hand, if you can (it is slipping), tighten slightly until you cannot. This will tighten the diff action you just set before, but you will need to find a happy medium or compromise between the 2.
Re: Blue pan
the spur gear should hold 1/8" diff balls. Won't work otherwise. The original gears only had 8 balls, lots of modern gears that fit pan cars have like 40 holes in them, you need to figure out which pattern fits on the diff rings correctly. If you've never seen it before, it makes sense for you to go through the manual for a 6 gear trans, and all will become clear.
starts on page 9:
http://www.teamassociated.com/pdf/cars_and_trucks/RC10/Team/graph_manual.pdf
JK Racing
Re: Blue pan
Post by JK Racing »
jwscab wrote:the spur gear should hold 1/8" diff balls.
edited my above statement, thanks for the correction.
Bent
Re: Blue pan
Post by Bent »
JK Racing- I completely get what you are saying. I will have to get a new old gear and a couple more small bits, before I can adjust it out to how i want it.
jwscab-Thanks for the link man. That will come in handy if i ever have to redo mine. Its certainly helped me under stand the 6 gear a little better.
Users browsing this forum: No User AvatarGoogle [Bot] and 15 guests
