THE BLACK THING (T2 hybrid...) NEED HELP WITH BODY!!!!
Re: THE BLACK THING (T2 hybrid...) NEED HELP WITH BODY!!!!
Have you tried a viper body? I just got one and lined it up against the bottom of the T2. Looks like it would be a pretty good fit.
Yeah it does fit pretty well but the nose is too short. I have another old viper body. So I think I will use it to make a longer nose that would stay permanently on the chassis. The actual body would be cut at the front shock tower...
- carloco8
- Has thanked: 74 times
- Been thanked: 273 times
I figured out my situation with this project. I did end up using an associated viper body, but cut the back off and pushed the body slightly forward to meet the front body mount. As for attaching the rear, I used something similar to the A&L rear body mount (mounts on the shock tower) and attached it to the front of the rear shock tower. I'm still trying to see if I can use regular 10t/t2 rear body mounts some how though.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
words, words, words,carloco8 wrote:I figured out my situation with this project. I did end up using an associated viper body, but cut the back off and pushed the body slightly forward to meet the front body mount. As for attaching the rear, I used something similar to the A&L rear body mount (mounts on the shock tower) and attached it to the front of the rear shock tower. I'm still trying to see if I can use regular 10t/t2 rear body mounts some how though.
- carloco8
I know, I know, everything has just been test fitted, nothing actually completed yet. Sorry for no pics yet, I guess I'm just teasing, but it should work perfectly. The rear of the cut body doesn't touch the rear shock tower, as there is a little gap, but it doesn't look bad.
- Synergy
- Has thanked: 127 times
- Been thanked: 72 times
How much longer is the wheel base than say a RC10 Graphite?
Here's my TC Showroom
- 1875 Views
Last post by Mr. ED
- 1687 Views
- 1250 Views
Last post by tdevilman77
- 1480 Views
Last post by vwjuice
- 839 Views
Last post by Goatless
- 1713 Views
- 1226 Views
Last post by RC10resto
- 427 Views
Last post by Lowgear
