The four holes were a later revision, the ones without are early.Asso_man! wrote:yep, and those four holes in the H arms are not present on mine, just plain plastic with no holes
The Next Level: Team Losi JRX2
- Eau Rouge
Yeah, I recall many of them happening when we were buying and building these cars. IIRC, the white steering bellcranks were early and had SEVERE breaking issues when the temps got low. They replaced those really fast. The battery box changes were necessity, too. The original one (on this car) was almost impossible to get wires or connectors in and out. This one was factory relieved for wires out the front (stick pack), but were still a PITA.aconsola wrote: Does the plate have the cutout up front for the inner camberlink mount?
do the side links have 2 shock mount holes or 4?
I'm just curious, not trying to give you a hard time
No cutout in the motor plate.
Side and rear links have 4 bottom shock mount holes.
It seems that like the rc-10 there were several changes during the production run for the jrx-2 and possibly jrx-t.
variations I know of:
black and white bellcranks
different motor plates
2 styles of rear bulkhead
battery box
rear suspension link changes
I also recall changes in the thrust bearing assembly, too. If memory serves me correct, the original was prone to failure in mod applications.
This car obviously wasn't an early production release, because it does have a few of the first kit updates in it. It's hard to tell what was original and what wasn't, because there were different color plastics in this kit, so the original owner may have replaced parts as they were broken during assembly (shock collars, shock cartridges, spring perches, etc.). Best guess it was probably a mid-age car during the entire JRX2 production run.
- Eau Rouge
Finally scanned the photos of my original car. I'm getting fuzzy with dates lately, but I believe this to be summer of 1988 or so.
The car evolved into this version with ProLine wheels and JG body mounts, as I began to run modified motors and 6-cells (called SuperStock locally).
It eventually was converted into a sprint car using an ASCOT RC10 frame and the cut-down stock chassis. I have photos of that car somewhere, if I can find them. That car worked REALLY well on ovals.
- mrlexan
- Been thanked: 10 times
Are you doing a retro paint scheme or going box art? I like the top photo.
You weren't kidding in your other paint post, you have been doing it a LONG while.
I think it is interesting, most of here are pretty much the same age and it appears that on our racers, we all had similar paint schemes (like the bottom photo). Must have been a sign of the times, as most of them today carry similar designs (meaning the pros).
- Eau Rouge
mrlexan wrote:Are you doing a retro paint scheme or going box art? I like the top photo.
You were kidding in your other paint post, you have been doing it a LONG while.
Yeah, the first car I painted was in 1983. Used Testors model paints. Whoops.
It will be period accurate, for sure. I may do one of the earthquake paint schemes like my brother and I used to run. I donno yet. I'd much rather have something similar to the bottom photo, for sure. Depends on how my body/wing search goes, really. I may use the stock original body to replicate my original 'quake scheme. Still undecided...
- Asso_man!
- Has thanked: 40 times
- Been thanked: 70 times
I vote for the bottom one, it's simple, has nice color scheme and is very convincing
Come and visit the stable
- MelvinsArmy
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
- Eau Rouge
Re: The Next Level: Team Losi JRX2
Just a little update on the JRX2 project...
The only real thing remaining on the car was the body and wing. The car didn't originally come with a wing from the previous owner, and the body was yellowed and had been cut out with what looked like a kitchen steak knife. It had also been partially masked at one point, with the original window masks still on the body from 1988.
I finally gave up looking for a replacement body for the car and decided to see how much life I could coax out of the original. Outside of the wing holes not lining up with the wing tubes, and the side pod holes being unnecessarily oversized, it actually cleaned up quite well. A few hours of surgery with about 6 different Dremel bits, an X-acto knife, curved Lexan scissors and multiple grades of sanding sticks, a lot of WD40 and denatured alcohol and it looks really clean. Almost as good as I could have hoped for, actually.
Now with the final acquisition of an original V-wing from Anthony (thanks), I can finally finish this car for display. I'm contemplating an era-correct paint job for this car, but I'm heavily leaning towards replicating/paying homage to the original Yokomo driven by Gil Losi Jr. to win the 4wd Worlds in 1985. Simple, classic and historically appealing at the same time.
I'll post photos tonight of the body as it sits now.
- mrlexan
I like the Gil idea Doug, but it is yours and so should be the final decision. I am sure either way it will look great. Can't wait to see painted pics.
www.gojammedia.com
www.gojammedia.com
- TUCRACEMAN
- Eau Rouge
You can see somewhat in the previous owner's photos the roughness of the body, but with a little massaging and Dremel work, it cleaned up pretty well. It still hasn't even been plastic polished yet.
Paint starts when the wing gets here.
- 1882 Views
Last post by Harvey Wood
- 2832 Views
Last post by MelvinsArmy
- 24 Replies
- 5827 Views
Last post by shodog
- 687 Views
Last post by purplenut
- 708 Views
Last post by Bent
- 1225 Views
Last post by hkp
- 1419 Views
Last post by matt1ptkn
- 2148 Views
Last post by bearrickster
