Thanks Rapscallion!!!
Hei! Cool! Those are the J82 wheels/tires on the front?Jeep-Power wrote:got mine in today-- they are perfect! The diameter is identical to the RC10T wheels.
Yes-- the J82 fronts & Proline SandPaws on the rear.rapscallion wrote: Hei! Cool! Those are the J82 wheels/tires on the front?
Would it be possible for you to take two photos from the same position with before/after showing the stock size wheels mounted on the car followed by the large? Either way, glad it worked out for youLet us know how it drives
It might not be bad to see the full OEM compared to the full mod set-up. No big hurry. Just would be curious to see the difference side by side.Jeep-Power wrote: Yes-- the J82 fronts & Proline SandPaws on the rear.
I can do that. Do you want the OEM rear tires on as well?
Good idea! I've already stretched the car out as far as it can possibly go - but I hadn't considered adjusting the camber. I'll definitely give that a shot before running the car again. Thanks for the tip!kdog wrote: Other adjustments for this setup: negative camber is really important for the balance of traction/not rolling in every turn, and I made the wheelbase as long as possible with the adjustment shims.
