My First Yokomo YR4-M2 Project
Lonestar
Has thanked: 623 times
Been thanked: 170 times
Re: My First Yokomo YR4-M2 Project
Post by Lonestar »
OldSkoolRC wrote:
Lonestar wrote:
OldSkoolRC wrote:Thanks for the heads up on the tamyia rally tires - will look into those.
Not sure I understand your comment about th open belt not being a good rally car option and I am perhaps confused since my yz10 is an open belt car that runs in dirt. Can you educate me here a little?
The pro comp- Per the yokomo USA touring car catalog that came with my car it was $198.00 option kit for the yr-4m2. I would snap a pic but I apparently have not graduated to picture posting status since my attachment button is disabled. Part number is : yr-4m2 pro-conversion
yz10 has a tub and wheels outside the body... your m4 typically doesn't have an undertray, plus the the tires are inside the body and they send tons of stuff in! belt-driven rally cars had tubs and sometime "inner" bodies (think hpi rs4 rally) :)
ha - yr4m2 pro-conversion kit, I think the idea was a conversion to M2 specs from M version :)
Paul
Okay that makes sense about the tires on the outside of the body and the tray under the yz10. I ditched the tray on mine since we were running on a very compact track back then with very little loose dirt.
So is there a yokomo that is shaft driven that could be used for rally? That hpi rs4 looks a lot like a yoke to me.
That makes sense about the conversion kit since a lot of the parts have identical descriptions as described in the parts list from the m2.
Any chance you can direct me to a good source for yz10 parts? I found the front belt pully i needed but would like to source a couple other items that i am not finding on eBay.
yoke shaft-driven = bmax, not modern tho
all double-deck, saddle-pack, belt driven touring cars bitd looked like the M2 ;)
yz10 supply source? ebay, mostly... or the BST here ;)
Paul
OldSkoolRC
Post by OldSkoolRC »
Thanks Paul!
Yokomo 870C, YZ-10, RPM YZ-10, Hot Dog, YR-4 M2, '91 Custom Carbon YZ-10, MR4-BX and some RC10's
Return to “Yokomo Forum”
