How to run modern rubber on your JRX series car
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: How to run modern rubber on your JRX series car
Cool...I just put the first one I found. Great, you can tell us/post pics of how it fits.
To add another "data point":
I picked up some B4 fronts (P/N 9588), and they will need to be spaced out more than I realized to fit (JrxPro SE). They sit just about perfect with a spare bearing on the front axle prior to slipping the wheel on. it's enough that the stock Losi plastic wheel nut doesn't self-lock (not enough threads to go all the way to the end of the nut), so I'll have to use a metal self-locking nut that isn't so deep.
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
Bearickster, did you ever try this?I agree I have them on the list for my next Tower order to check them out and see if they would fit.
I have a few thoughts on what may work. As some of you are aware, JC Racing products sell a complete line of 2.2 inch 5 spoke rims for a variety of buggies. They seem to have everything covered except pre-xx Losi's. They have rims for RC10, B4, Kyosho, Tamiya, Mardave and Traxxas. Many others too.
Can anyone confirm if Mardave Cobra, Hornet or Traxxas rims can be easily adapted to the Losi front axles? Mardave Cobra rears look like a pin drive. Not sure about Traxxas. Obviously not the Hornet. I currently do not have any of these in my stable so I cannot check myself.
Cheers
- JK Racing
The RC10 fronts should work with no issues. I cannot comment on the Mardave, but the other 2 are metric, so I dont think the bearings will seat properly.
The B4 rears "should" work, with original RC10 fronts....
my guess is that the traxxas ones might be the best fit, for offset and axle sizing. the axle sizes are metric, but you can use spacers up front, and I'm not sure what the rear wheels use for drive mechanism, but it would be either a pin or hex drive, both of which are easily used on the 3/16" axle(rear wheel would use a 5mm axle, very close to 3/16", just need to open the hole up. I believe the traxxas offset is closer to losi than the associated ones.
EDIT*: I just checked out his auctions, it appears they are pin drive, which means they should fit pretty easily.
No pre-XX Losi b/c they are the same size and offset as the 3/16" RC10 wheels, which they stock.8rad wrote:
The XX and later wheels are for the later cars or for the JRX* series with a XX-style in-carrier bearing system.
- 8rad
So the RC10 fronts are a direct fit? No shims? Also, the xx rears dont match the RC10 fronts.No pre-XX Losi b/c they are the same size and offset as the 3/16" RC10 wheels, which they stock.
The idea is to have a full set of matching rims with as little modification as possible. If the RC10 rims fit then great no problem.
I guess I need to buy some to find out.
- 8rad
I sent an email to JC Racing products asking if they would be willing to make some Losi pre-xx rims in 2.2 and offered to sent them a set of rims to copy the bearing sizes and offsets and this was their response.
"Hi Jeremy, Most certainly would consider making some. Please forward to the following address (We will return these)"
So off with the rims. We will see what happens!
Should the fronts be wider to accept modern 2.2 fronts? The losi rims are quite a bit narrower than what I run on my Cougar.
Cheers
Cheers
What do you mean "the xx rears dont match the RC10 fronts"? If you are buying a full set of the RC10 B2/3 wheels from these guys, you will have the fronts and the rears to match.8rad wrote:So the RC10 fronts are a direct fit? No shims? Also, the xx rears dont match the RC10 fronts.No pre-XX Losi b/c they are the same size and offset as the 3/16" RC10 wheels, which they stock.
My understanding is that the rear axles are the 3/16 ones (same as JRX2) and the front wheels will fit the JRX2 axle with the Associated flanged bearings, just like all RC10 wheels will fit a JRX2 with the appropriate bearings.
Without spacers, the JC RC10 wheels are a direct offset match with the original box JRX2 wheels. You only need to space them out if you want additional front track, which most people do want, and you would have to do that with the stock JRX2 rims anyway.
I wonder if they will make a new set of wheels for the JRX2 (if they would make a 5-spoke 2.2 inch wheel in the style of the original JRX2 wheels, that would be awesome), or if they will just point out to you that the size and offset of the wheels is identical to the contemporary RC10 wheels, and direct you to purchase those instead.
- 8rad
I did not realize the RC10 rears were a direct fit to JRX. I thought the drive pin and axle sizing was different.
Anyhow, I am going to send them the JRX spoked wheels and ask them to copy those in 2.2.
Regardless it will be nice to have Losi rims for Losi buggies. I just cant stand the thought of fitting RC10 rims on my PRO.
YUK!
YUK!
You are absolutely correct and I apologize.
I just re-read the JC Racing listing and they are listed as the 1/4" axle, like the original and sport models, not 3/16" like later RC10s and the JRX2.
Sorry if I confused anyone ... and I suppose this underscores the need for JC Racing to make dedicated JRX2 wheels ... which will also work on a 3/16" axle RC10.
I hope they think to make a flat-faced 5-spoke like the original JRX2 kit wheels ... there are plenty of dish wheels already available ...
- Been thanked: 4 times
So did anyone ever actually find a way to run 2.2 wheels and maintain the max width without using spacers?
- 8rad
I just sent a full set of original JRX-2 rims to Colin at CB Patterns. AKA JC racing products. I asked if they could reproduce the same wheel in 2.2 to fit the JRX-2/PRO/Junior 2. I will let everyone know what happens if anything.
- 1412 Views
Last post by Mr. ED
- 2726 Views
Last post by OldSkoolRC
- 1070 Views
Last post by fastang
- 209 Replies
- 65219 Views
Last post by rctenracer
- 858 Views
Last post by slapshot1979
- 906 Views
Last post by WriteDean
- 718 Views
Last post by Toyotachris1982
- 23 Replies
- 3952 Views
Last post by Johanp
