Project RC10 MIP Legend 4-10 (Aug 9th, 2011 updated)
m_vice
Re: Project RC10 MIP Legend 4-10 (Aug 9th, 2011 updated)
Post by m_vice »
That looks good man, cant wait to see more. :D
Has thanked: 239 times
Been thanked: 337 times
Hey did this build use the RPM rear end as well?
minimini
Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
Been thanked: 11 times
Post by minimini »
Charlie don't surf wrote:Hey did this build use the RPM rear end as well?
I can only afford using RPM rear arms (black color) only. :(
For the rear bulkhead & arm mounts, just stick to original. :(
tiger1
Been thanked: 7 times
Post by tiger1 »
why did you cut off the bottom of the rear bulkhead?? better CG?? :D
minimini
Post by minimini »
tiger1 wrote:why did you cut off the bottom of the rear bulkhead?? better CG?? :D
for easy fitting of the battery only, no need to "squeeze" the stick pad into the tiny little hole. :wink:
BTW, I bought the chassis stiffener from Daryl recently, really keen to put it in this project, but after reading Emerson's thread about his Legend 4-10 project........seems that adding the stiffener plus the drive belt on top, the space will be tight..... :( .......anyone got a solution ??.......thanks !! :)
http://www.rc10talk.com/viewtopic.php?f=35&t=21876
tiger1
Post by tiger1 »
minimini: I do have an idea that will work :)
Jordanny
Post by Jordanny »
I don't know what topic to ask but I think people can help me out
I have 1 legend 4-10 but NO drive belt, I check with HPI 4mm the teeth perfect fit but too short for it. Does anyone know what size of the belt and how many teeth does it need? very hard to find the mip legend belt only belt I think from HPI. Please help me
Has thanked: 1079 times
Been thanked: 3726 times
I don't have a great answer for you but....
You could take the long hpi belt and route it as it should be, and measure how much too long it is. Subtract that from the length of the long belt and you should have a pretty good approximation. You know the pitch seems ok so just finding a proper length or tooth count is all that is left
