2010 Vonats Racer Build( New Chassis color (s)
slotcarrod
Been thanked: 45 times
Re: 2010 Vonats Racer Build
Post by slotcarrod »
Popps 59 wrote:You have to drill out the castor blocks to accept the 1/8" pins, and the same for the rear blocks, other than that--no changes.
And what is it with the Canadians asking dumb questions about holes? :roll:
Reggie @ Pop's PC ( he forgot his password :| )
Any chance we get to bug Reg, we will! :twisted:
Pop's, did you get your tires yet that I sent you?
tecnica2001
Has thanked: 19 times
Been thanked: 29 times
Post by tecnica2001 »
What Tierods are those?? RC10B4??
Has thanked: 358 times
Been thanked: 470 times
They are B3 era FT. 1.35" & 1.85" with Losi ball cups
Yes Rod, I got the tires ( and the Toonie :lol: ) bu tmy 5 year old took the Loonie and the Toonie, and I forgot the tires on my way to NY :|
slotcarrod
Old age creeping up on ya Reg! :lol:
59burst
Post by 59burst »
which B3 hub did you put on yours Reggie? B4 25 deg. has more kickup than RC10 stock 25 deg. so, B4 20 deg. hub is better for RC10 unless you like understeer 8)
The B4 has a static k/u of 25 deg, the RC10-B3 has 30 deg Static k/u-
The B4 blocks on a RC10 have + or - change depending on the direction they are facing which may be used to change the wheel base or the steering arm location
(20 deg) 5 deg
(25 deg) 0 deg
(30 deg) 5 deg
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Post by vintage AE »
Reg,
What shocks are you using in both the front and back? I got a set of worlds towers from Fibre-Lyte and RPM arms, so I imagine I would use the same size shocks.
And same length tie rods, which I noticed the length above.
Great thread, thanks!
Those are 1.32/.71's- But it will have .89 fronts ( with .71 shafts ) and 1.18 rears ( with 1.02 shafts ), because of the threaded option. And the Fiberlyte variation would be the .71/1.32//1.02
vintage AE
just so I'm on the right page here, the .71 shocks are the B4 fronts and the 1.32 shocks are GT/T4/B2/B3 rears?
I am thinking it will be easier to search ebay for a set of shocks and not many are listed using the lengths.
The .71/1.32 is the standard team car length. But the rears are the same as the B2/3 and the T-T2/3. The .89 fronts are B2/3/4
Bormac
Has thanked: 20 times
Been thanked: 11 times
Post by Bormac »
I like the vintage racer build you have there Reg. What class will you run? OPEN?? :mrgreen:
-Jason.
Still known as- bormac
:lol: I have always been a much stronger driver in Mod then stock, the 17.5/13.5 classes are so much quicker that I really think that's quick enough to be good.
A bit of an update~ While at my folks place I have acess to my mill 8) So I thought I would show some rear carrier mods to stock B4 hubs
And I machined some VLA Losi hubs ( that EA3 plastic is not fun to machine :? ) just for a possible difference in adjustability
And after all this I think that I am going to go with Jeff's setup of the Racers Edge Hub and the CVA
A bit more done, while I have the mill at my fingertips :P
Take one block of Delrin
Turn some handles 8)
And wala~ Battery retainer
Oh, and of course you knew this was coming :roll:
Some closer to finished pics--
More to come once some tires
arrive
you stole my idea on that battery retainer........ kinda. mine was gonna look a little different. i had plans on incorporating a servo mount into it.
scr8p wrote:you stole my idea on that battery retainer........ kinda. mine was gonna look a little different. i had plans on incorporating a servo mount into it.
You kinda had the same idea I did, you were just going to do it a little different
Users browsing this forum: No User AvatarYandex [Bot] and 13 guests
