Edinger Kit Manual / Replica of Backpage RC10
Re: Edinger Kit Manual / Replica of Backpage RC10
the shock bodies and caps were glass beaded then sanded by hand. might have stripped them with greased lightning......... i really don't remember.
the collars are hot trick i believe. i got them from another member a year or so ago.
THE H.P FREAK
Post by THE H.P FREAK »
HI!... Well I might have to try some CITRISTRIP on the shock bodies then. I know it strips off several layers of skin off my hands easily! :mrgreen:
Gizmo
Post by Gizmo »
Scr8p
What did you use to dye the white parts ??? I going to restore mine and the old parts are black and replacement ones are white
Cheers
Giz
THE H.P FREAK
Gizmo wrote:Scr8p
Cheers
Giz
HI!... Just use RIT fabric dye. You can find it at any fabric or craft store. Just boil some water in a stainless steel pot. Turn the heat down to low simmer. At RIT dye powder. Stir around. Add parts. I usually leave the parts in for a hour to make sure the colour seeps in.
freshly re-ano'd parts. :)
Synergy
Has thanked: 127 times
Been thanked: 72 times
Post by Synergy »
They look nice Scr8p, what prep did you do on them, just bead blasting?
Here's my TC Showroom
bearrickster
Post by bearrickster »
That Really looks Great :D nice Job
LOSI RULES!!
Bearrickster's Rides
Synergy wrote:They look nice Scr8p, what prep did you do on them, just bead blasting?
i glass beaded just the bottom of the tub and nose plate to remove the ano quickly. then hit them with 80 grit on a da sander to feather out the scratches. stepped that down to 150, then 320, then 400. after that, i used a somewhat worn out red scotch brite pad to give it a uniform finish. jeff said i didn't have to worry about stripping everything, the place that did the ano would take care of it. so i only stripped the areas that needed to be fixed.
Has thanked: 356 times
Been thanked: 470 times
That's not the chassis I gave you- ( looks great though :lol: )
still have quite a bit to do, but i threw some of it together. i need to peroxide a spur, get new ball cups for the sway bar, piece together an edinger steering bellcrank, make a rear swaybar, get new hardware for the front wheels, and ultimately get a body and wing painted.
Too cool 8) 8)
Ruffy
Been thanked: 66 times
Post by Ruffy »
Very nice so far Scr8p!
Lovin' this build, keep up the good work.
CamplinP
Post by CamplinP »
Looking Sweet!
i'm really not a fan of black parts on a gold tub, but with how light the gold is on these parts, it doesn't bug me near as much as it does on the darker orange/gold stuff.
mrtallguy
Post by mrtallguy »
nice build going on there
Users browsing this forum: User avatarhowsyouraspen and 3 guests
