1992 RC10 CE Tires/wheels? Motor?
SnoopMaxx
Re: 1992 RC10 CE Tires/wheels? Motor?
Post by SnoopMaxx »
That's what I call a mix of old and older parts :shock:
Great looking car :D
Morten Max
ddogg17
Post by ddogg17 »
Yep. Everything is OEM, except for the motor, which is INOP. I even have the original box, owners manual, a box of unused parts, that the kit came with and the OEM tools. I hooked up a battery to it. All electronics work, servos, everything, but no motor. Hooked up an ohm meter to the motor plug, it is getting power, just the motor does not work. But with a good recommendation on a motor, and hopefully find tires, I think this car is good to run. I would also like to find an unpainted body and do a really nice paint job. Now, talking with everyone here and from what I learned, I better go easy on it, and not risk breaking anything. Just keep it old school vintage....
The reason I even brought this thing out of the garage, is that my buddies got some new Traxxas Slash 4X4's. I had this weird idea that since the original RC10 box said 2 time World Champion, I would have no problem keeping up. Guess I was wrong huh....? Oh well, now that I am this far into research, might as well fix it up....
fastang
Post by fastang »
scr8p wrote:
fastang wrote:I think we should see the bottom of the chassis before we go any farther with suggestions.
what for, so we can tell another person to go buy a beater off ebay because the one he has is too nice to use? :lol:
I suppose I deserve that :lol:
This car is in nice shape but not too nice to be a light runner. Bottom of chassis looks good with minimal scratches. If you are going to run it I would protect the chassis with a protector of some kind. Thick tape works well. With the 6 gear tranny and no holes for a stealth I would keep it mild as far as motors and electrics go. I personally wouldn't drill it for a stealth. Plenty of CE's on ebay for cheap :wink:
And please don't dye any of the white parts ANY color. If you want black stuff contact me and I will trade you white for black!
ddogg17
Post by ddogg17 »
Thanks for the advice. Wasn't planning on dying any of the parts. What to leave it as OEM as possible. You got a recommendation on a brand and type of motor? 27 Turn vs. 19 Turn? How about a brand name? Then just need to figure out the tires, hmm....
ddogg17
Post by ddogg17 »
Here is another question? What year or years, or models, were the rims/tires the same for my car? I see many options on ebay, but just not sure which will work and which ones will not.....
christhepcguy
Post by christhepcguy »
I've got the same 6 gear CE I just started working on. I just bought some ofe these tires http://goo.gl/mDeY
They should be here tomorrow. I'll let you know if they fit. They do say 2.0 inch. and they were only $10.00
ddogg17
Post by ddogg17 »
Yes christhepcguy. Please, that would be great, let me know if they fit.....What tires are you running for the fronts? What motor you running?
badattitude
Post by badattitude »
Nice car, if you are going to actually use it you may want to get an Electronic Speed Cntrol. They provide smooth throttle responce and you'll get more from your motor. I found this one ebay that you may consider and I also include a link to a new one at tower.
http://cgi.ebay.com/Vintage-Novak-Fusion-ESC-Electronic-Speed-control-rc-/300419121080?cmd=ViewItem&pt=Radio_Control_Parts_Accessories&hash=item45f25fffb8
or
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGZX1&P=ML
these 2.0 rear tires will work for you as well
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGD99&P=7
It's harder for me to find 2.0 fronts, no sugestions for those.
christhepcguy
ddogg17 wrote:Yes christhepcguy. Please, that would be great, let me know if they fit.....What tires are you running for the fronts? What motor you running?
Fronts are stock that came with the car. I have a Speedworks Speedjem motor and some Reedy motor. Came with the car when I got it from craigslist. They are both same era motors so should be fine.
ddogg17
Post by ddogg17 »
Thanks guys. Here is a curve ball. Notice the pictures of my rims. Then look at the picture that Charlie don't surf posted. My rims do not have have the 3 screws in them. I just noticed that my front rims say "Proline" on them. Did Proline make rims that year? The front tire's are Team Associated. The rear tires are 12.5-20.....You think my wheels are different size than stock?
badattitude
those proline fronts are not stock, but are a fine wheel. It's 2.0 inches inside diameter.
the rear wheels look like stock that came with your car new and are also 2.0
ddogg17
Post by ddogg17 »
Right on man. Thanks for the help. Being Proline wheels in the front, will it be easier to find a front tire?
badattitude
unfortunately no, it's still requires a 2.0 inch front tire. they pop up on eBay occasionally.
ddogg17
Post by ddogg17 »
Hey guys. I found a company still making wheels for the Vintage RC10. Company is based in the UK, called http://www.jcracingproducts.co.uk/. Looking at the rear closely, I see that groove cut into them, to fit the original drive and bearing arrangement. I asked and they say, they are designed to fit, "modern" sized tires....
They make only one style, the 5 spoked, which is pictured below. 3 colors, white, black and yellow....
Anybody heard of them?
Users browsing this forum: No User AvatarTbot [Bot] and 11 guests
