2010 Vonats Ultima buildup....
- Brandon G
Re: 2010 Vonats Ultima buildup....
Anybody know off the top of their head what the tranny gear ratio is on an Ultima Pro?
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Not sure about that: my ultima pro came with the 0.5 (or is it 0.6?) module spur. I don't know if it's the original one I still have but it i is slightly larger in diameter than the 32 pitch ones and another 0.5 module one I have in my spares case.
A larger diameter indicates a different ratio...
- Brandon G
I'm more concerned with the gearbox ratio. (stealth is 2.25:1 for example) I am using a non stock spur gear, the 42p thorp, so I will have to do my own calculating when it comes to choosing a pinion.
- RichieRich
Wow, 42 teeth? The stock one is 44. So, you'll have to use a tiny pinion to get a usable ratio. BTW, 3.03 is the ratio of the topshaft/diff including the two smaller gears that are not adjustable.
- civilguy
- Has thanked: 5 times
- Been thanked: 14 times
He won't have to use a tiny pinion if he's running 17.5BL. I had to pick up 28-32 tooth pinions for my Rad2 when I ran it last year with a 17.5. A 27t motor and I would have been running 10 teeth less. The rpm difference is massive, but the torque on those 17.5 motors is awesome.
Jeff
Jeff
- Brandon G
No, 42 pitch. I can't remember the spur tooth count off the top of my head, I'm thinking it was like a 70???RichieRich wrote:Wow, 42 teeth? The stock one is 44. So, you'll have to use a tiny pinion to get a usable ratio. BTW, 3.03 is the ratio of the topshaft/diff including the two smaller gears that are not adjustable.
Like Civil said, the 17.5's love to be overgeared, so I think it won't be too much of a headache to get it right.
- Has thanked: 7 times
- Been thanked: 42 times
42 pitch?!?! Whatchu talkin' 'bout Willis?
Never heard of 42 pitch before. Who? Where? What?........Why?
- civilguy
0.6mod is 42.3333 pitch. That's probably what it is... Thorp was a USA company so they probably called it 42pitch. Just my guess.
Jeff
Jeff
- Brandon G
Thanks Jeff.
Yeah, try running a 48 pitch pinion on the older fine tooth Kyoshos and see what happens....
- RichieRich
- Mr. ED
Did Thorp make 0.6 module spurs for the ultima? Their diff and top gear are 48 pitch thopugh... not?
- Has thanked: 36 times
- Been thanked: 1319 times
wasn't the "BK pitch" like a 42 or something like that? or was it in between 48 and 64? i don't remember......
I'm pretty sure BK pitch was between 48 and 64. Good info on the "42" pitch gears, thanks
- 1917 Views
Last post by kaiser
- 26 Replies
- 2727 Views
Last post by Mad Racer
- 1676 Views
Last post by bearrickster
- 745 Views
Last post by drbelleville
- 27 Replies
- 2522 Views
Last post by Brandon G
- 673 Views
Last post by soniccj5
- 163 Replies
- 16499 Views
- 62 Replies
- 6703 Views
Last post by Kyosho Fan2
Users browsing this forum: DotNetDotCom.org [Bot] and 2 guests
