differences in the trannies
General info, Q&A.
ra272
Been thanked: 7 times
Post by ra272 »
No, and if you have an early chassis, It will be impossible to fit a stealth without drilling it...
The older chassis (with a A under the motor) have only holes for the 6 gears, after there where chassis with both 6 gears and stealth holes (B) and last chassis with both holes but not contersunck for the 6 gears (C gold or black).
Brat
Post by Brat »
Drilling is not a problem as I own one. How much better will the stealth out perform the 6 gears? Speed, acceleration etc?
carloco8
Has thanked: 74 times
Been thanked: 271 times
Post by carloco8 »
The stealth will outperform the 6 gear trans in all those areas. It has less gears, for less rotating mass making it just more efficient and smoother.
Brat
Post by Brat »
carloco8 wrote:The stealth will outperform the 6 gear trans in all those areas. It has less gears, for less rotating mass making it just more efficient and smoother.
In That case, I think I really need to get a set! Btw, where can I get the alu type stealth, if available?
