RPS = Losi.mytimac wrote: #1 is Losi
http://sabulatech.com/storefront/product.php?id_product=1390
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 56 times
True, but people don't always list them on eBay as RPS or Ranch Pit Shop parts. The header card only shows that on the back. The front is Team Losi. So I wanted to point out that for others looking for info that it is Losi part.Phin wrote:RPS = Losi.mytimac wrote: #1 is Losi
exploded view will work. want it for screw sizes. and if it has part numbers also. so I can double check what others are selling make sure its right.EvolutionRevolution wrote:TF-2 and TF-3 parts are compatible. Official Kyosho part numbers usually start with SP, SPW + some OT (some parts are only for the GP Spider though). Anything by other manufacturers for a Kyosho Spider or TF series may also work.alien3t wrote:thanks guys. now to go back see what kyosho parts are in the 75% off bin for it.
None online, I'll check if I already scanned in mine. Would an exploded view also work?cAN NOT FIND A INSTRUCTION MANUAL FOR THE tf-2. dOES ANYONE HAVE A COPY, OR ONLINE, BEEN SEARCHING ALL MORNING.
thanks.
Looking to fix up an old OFNA Pirate 10, gearbox was modfied by previous owner to a two speed. Spur gears are stripped and I'm not having much luck identifying them, so I thought I'd give it a shot here.
Once side is completely flat, the other is sunken with four locating pins.
Third picture shows the parts that make up the gearbox, top two parts I believe are original to the car, but the rest probably aren't.
alien3t wrote:Owner of shop gave this to me. Thought it was for a Tomy, doesn't seam like it. anyone have a better clue. The screw holes at the ends don't know any car with that bulkhead screw pattern. He doesn't know how long he has had it or where it came from.
WEll emailed Kyosho America, they sent me over the instruction manual for the TF-2 Type R, and the regualr TF3. so if anyone knows how, like to add the PDF files to the instruction sections. so they are there for future. Unless to knew, but the TF2 is about 18 years old? and the TF3 is 16.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
If you've got a PDF file, but don't have anywhere to host if for downloading, you can convert the pages to JPGs using an online converter.
whats a good place for hosting a PDF, figure easier for people say if they want to print it or anything. BEtte than taking 50 pages total to photobucket then put every link onto the comment box.
I would be grateful to have access to those manuals and to my knowledge they don't exist on the internet, you might contact Competitionx.com. those are on their want list.WEll emailed Kyosho America, they sent me over the instruction manual for the TF-2 Type R, and the regualr TF3. so if anyone knows how, like to add the PDF files to the instruction sections. so they are there for future. Unless to knew, but the TF2 is about 18 years old? and the TF3 is 16
are they on Tony's list at Competitionx. Ill text him and ask.
- Has thanked: 1129 times
- Been thanked: 3919 times
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Sounds about right.alien3t wrote: Unless to knew, but the TF2 is about 18 years old? and the TF3 is 16.
- Phin
CRP body for the Futaba FX10.
http://www.rcchopshop.com/crp/6002.html
EDIT: Lines don't look very sharp though...could be a repop?
- 59 Replies
- 16057 Views
Last post by Diamond Dave
- 106 Replies
- 27086 Views
Last post by mikesofunny
- 431 Replies
- 54364 Views
Last post by Eccentric
- 67 Replies
- 16810 Views
Last post by bearrickster
- 321 Replies
- 41828 Views
Last post by tazz888
- 448 Replies
- 49912 Views
Last post by MelvinsArmy
- 351 Replies
- 47434 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
