Dadio's 3D Printing Stuff
- Has thanked: 2757 times
- Been thanked: 2250 times
Re: Dadio's 3D Printing Stuff
Mini Mustang arms
Couple of quick n dirty test prints of a lower arm and steering hub for the Mini Mustang , the suspension pin surround on the arm was only 5.8mm on the original and that looked too fragile for a printed part so I upped it to 7mm and it still fits fine .
Top arm , kind of feels like cheating as all four corners use the same suspension components
rear shock mounts
Started on the PB Mini Mustang Chassis , not finished yet as I'm starting with the left side and only the elements that are mirrored on the other side , no motor hole yet but my brain just turned to mush so it's time to stop . Yesterday I also drew up and test printed the motor plate , then adjusted it a bit and re printed , now its pretty much spot on .
The chassis is so long I can't print it in one part , I don't think its professionally printable either so I think I'm going to find a way to split it , fortunately there's plenty of space inside to make a join that's strong enough.If a jobs not worth doing then its certainly not worth doing well.
- silvertriple
- Has thanked: 749 times
- Been thanked: 1322 times
Nice work!
The long chassis maybe printable... But it all depends the process you want. I saw some providers able to do MJF with a max build size of 380*284*380mm, and it is often bigger builds on SLS with 360x360x420mm or even 630 x 330 x 550 mm (natural)... It is worth trying to upload files on online services and try. That being said, the price might be super high.
Have the considerations with the Hirobo Bearcat chassis, by the way (about 386mm length: That being said, there is a lot of room available so it is possible to separate it in two parts, and add a link with screws in the middle...
Doing a test print of the front end now , fingers crossed
This is the completed chassis without the unique parts for left or right , I thought it best to test print this before going any further in case something complicated needs adjusting that would be more difficult with extra elements involved .
Result of the front test piece , it's mostly very good
, there's a few things like the servo cut out that needs to go forward 1.5mm , the diff bearing seats are slightly off but all the screw holes line up and the suspension fits perfectly .
Rear test print , overall very happy , much like the front some minor adjustments needed.
- Incredible_Serious
- Has thanked: 1735 times
- Been thanked: 1145 times
I am certainly liking this..... I would probably like it more if there was room for a 'regular' shape battery through the chassis..... but still, buggers can't be choosers.....
Keep up the good work, mate!
I'm starting with a faithful reproduction , later once the important geometry is right I can make a version that's modernized , stuff like the battery slot being able to take modern lipo's , slightly larger self tapping screws along the top ,a better belt tensioner screw solution with a captive nylock nut and to actually have a slot so the steering servo wire can exit .Incredible_Serious wrote: ↑Fri Jun 24, 2022 2:24 am I am certainly liking this..... I would probably like it more if there was room for a 'regular' shape battery through the chassis..... but still, buggers can't be choosers.....![]()
- silvertriple
Just a suggestion, my friend : While modernizing stuff, rather than self tapping screws, I would consider captive nylstop nut and machine threaded screws: self tap thread always become an issue, sooner or later...
Self-tappers are never an issue.... there's always replacement wood screws available, of ever-increasing sizessilvertriple wrote: ↑Fri Jun 24, 2022 3:48 am Just a suggestion, my friend : While modernizing stuff, rather than self tapping screws, I would consider captive nylstop nut and machine threaded screws: self tap thread always become an issue, sooner or later...
- 271 Replies
- 20258 Views
Last post by TravelinTravis
- 20 Replies
- 6786 Views
Last post by finman
- 1431 Views
Last post by Dadio
- 2282 Views
Last post by Dadio
- 1884 Views
Last post by morrisey0
- 3007 Views
Last post by j-sou
- 2167 Views
Last post by Smooth
- 1167 Views
Last post by silvertriple
Users browsing this forum: Tbot [Bot] and 2 guests
