Wow, that's like a 6.5:1 final ratio.... Are you sure you didn't mean 18t pinion? 28 seems a little large. Most stock brushed motors (I know you are using BL in this case) like a 9.5:1 final ratio for 2wd buggy. (please understand I could be entirely wrong here) In my case when switching to BL from Br, I only made a 1-2 teeth larger change on the pinion.Mark Westerfield wrote:28/81 for a novak 17.5 with lipo with a 2.25 stealth and current 2.2 buggy tires.
*** The official VINTAGE OFFROAD NATIONALS thread ***
- Brandon G
Re: *** The official VINTAGE OFFROAD NATIONALS thread ***
Actually that's a pretty good/safe starting point for a 17.5. Some guys go even higher. We've been running 5.6 to 6.4 FDR, even with some timing from the speed control. Some guys are using no slipper adapters so they can run smaller spur gears. Definitely start with the smallest spur that fits/is available. I know its hard not to think you are going to lose punch, but it never seems to happen. It still attacks the big Supercross style jumps.bngiles wrote:Wow, that's like a 6.5:1 final ratio.... Are you sure you didn't mean 18t pinion? 28 seems a little large. Most stock brushed motors (I know you are using BL in this case) like a 9.5:1 final ratio for 2wd buggy. (please understand I could be entirely wrong here) In my case when switching to BL from Br, I only made a 1-2 teeth larger change on the pinion.Mark Westerfield wrote:28/81 for a novak 17.5 with lipo with a 2.25 stealth and current 2.2 buggy tires.
Of course whether or not you want to run a vintage car like this is perhaps another matter, but the 17.5 motors can handle it. Unless perhaps if its significantly overweight, or an older higher drag tranny (6 gear? bushings, etc). The gearing mentioned is on a modern buggy right at the weight limit, using lipo.
But we also run brushed 27T stock higher, up around 8.0 FDR, so your mileage may vary as they say. Of course with brushed you can't run real long this way, but no issue so far with the brushless.
- Has thanked: 14 times
- Been thanked: 39 times
alright guys, here is my RC10 Team Car with a 17.5 Novak brushless motor and lipo battery. I'm (expert driver) racing the guys in the amateur 4wd class. My fast lap was a 16.6 in that race and my time was 27 laps in 8:01.
http://www.youtube.com/watch?v=qPmuohuUBQQ
- MelvinsArmy
- Been thanked: 11 times
I thought I was excited about this race before. Now I am.... well in the words of Stimpy: "I'm so excited I can barely contain myself!"Mark Westerfield wrote:alright guys, here is my RC10 Team Car with a 17.5 Novak brushless motor and lipo battery. I'm (expert driver) racing the guys in the amateur 4wd class. My fast lap was a 16.6 in that race and my time was 27 laps in 8:01.
- Has thanked: 19 times
- Been thanked: 29 times
Man, I'm gonna have to get there soon to get a couple of laps in, I haven't raced anything in so long, it's definitely going to be fun...
Yeah, I had just raised my ride height before the race and I raised it a bit too muchcarloco8 wrote:Nice vid Mark, the car looked overly dialed.......... traction roll!
- Has thanked: 183 times
- Been thanked: 157 times
thanks for sharing your setup info, it is MUCH appreciated.
thanks also for the vid, there is absolutely no way i will be able to keep up.
very nice mark! now I am pumped too. cant wait to see your set up sheet. is this the same layout that the nationals will be held on?
- mrlexan
- Been thanked: 12 times
Just FYI guys, I will be posting some pics here and also sharing some with Jimmy at Oople.
www.gojammedia.com
www.gojammedia.com
- Has thanked: 36 times
- Been thanked: 1320 times
thanks for the video. now i know where i'm gonna stuff hoopty every time i come up to lap him.
- loneranger
- Regular Member
Are the mains and qualifiers 5 or 8 minutes?
Tom Loranger
http://www.18thScaleRacing.com
I asked before and they said 5 minutes
- loneranger
- Regular Member
Cool, thanks.
Tom Loranger
- 321 Replies
- 42066 Views
Last post by tazz888
- 448 Replies
- 50332 Views
Last post by MelvinsArmy
- 67 Replies
- 16834 Views
Last post by bearrickster
- 41 Replies
- 19691 Views
Last post by R/Cat
- 192 Replies
- 28828 Views
Last post by Erich Reichert
- 311 Replies
- 47461 Views
- 228 Replies
- 40678 Views
Last post by 85Edinger
- 222 Replies
- 31171 Views
Last post by tecnica2001
